I came across the super rare K1500 Centurion Edition crew cab for sale near me.
Just wondering if these are legitimately as reliable as the standard K1500s from the 90s.
As far as I know, this is a conversion done by taking the cab from a K2500 or K3500 and sticking it onto a K1500 model.
The info i've seen says the frame had to be lengthened to accommodate the larger cab.
Any feedback is appreciated.
Brandon
I've also seen one around my town.  I wouldn't see any reason that they are less reliable.  Id love to see the link to the for sale ad if there is one.
It's facebook ad, I'll see if I can link it here
https://www.facebook.com/marketplace/item/792267670955237
Edited by croomz
  • 2 years later...
Need your guys' expertise. Talked a friend of mine into buying a 96 crew k1500 only to find out later what the "centurion" on the door and tailgate meant. Long story short, he bought it as a mechanic special as it would not start and had other issues, and i convinced him i could fix it no problem. I am pretty much the around town hobbyist mechanic guru for this area for this kind of stuff (LS swaps, tuning, custom wiring, transmission rebuilds, custom builds etc..). Got the starting issue figured out pretty quick (P/N switch on the transmission was messed up).
So this particular Centurion has the 5.7 with the 4l80 and 10 bolt rear axle. Not sure what the chances of this are or if it had the 80 swapped into it as some point. What we have found is that the RPO sticker, wiring harness and ecm in the truck are actually for a 5.0 and 60e. We have found the 80e connector had the normal 3 wires modified to adapt so that it would function. But my experience tells me that the ECM needed to be modified for this combo to work correctly. The issues we adopted in this truck is the fuel trims adding about 50% fuel and the torque converter stays locked up. My main question to you all....is it possible that Centurion had the ability to update/calibrate the ecm for this combination? Did someone else throw this 80e in later and mess everything up? According to our scanner, the ecm has the 5.0 VIN# in it. Did they make all these changes and leave the RPO sticker stock from the factory? Thanks in advance
Edited by Ranger6202
Ranger6202 - If you are the same person as the Ranger6202 that posted about LQ4 and LQ9 using the same stock tune. I'm looking for more info on this. Thanks.
really late on this one but heres my 2 cents  ive seen RPO codes differ on certain packaged or tailered trucks over the years. but from my experience it would be small OE stuff that wouldnt be updated for the sticker in the Glove box. however the VIN should reflect these changes esp if a coach builder modified the drive train or major componets. to my knowledge the combination of the parts you listed is not normal even in the Centurion packages.
5.0 ECM
5.7 engine
4l80E trans
10 bolt rear
it should be a 5.7 engine ECM 4l60E 10 bolt config or the less common "heavy half ton" 5.7 4l60E 14 bolt Semi float rear.
sounds like to me someone did a half ass swap
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
