After market remote starter
I am looking for input on an aftermarket remote starter on a 2017 2500HD WT with keyless entry, found out today from dealer this truck has no OEM remote starter available.
We do have a very reputable aftermarket enterprise close by that install these and stereo systems.
Anybody experience problems after installing one in a truck like mine? And why in the world would Chevy not have this available when spending this kind of money for a truck.
Work truck or not, blows my mind nowadays.
We had an aftermarket on our Trailblazer. Only input I would say is stay away from CompuStar.
Viper is decent, but the CompuStar got stupid after 7 or 8 years. A friend also has the CompuStar, and same issue - car acts up because of remote starter.
Everyone has different experiences I guess. I have added compustars to my trucks and the only trouble I had was with 2 remotes quitting but always got a new one under warranty. Other than that no troubles. I like them becaause they can be set for 45 minutes. When it is -40 ten minutes doesn't warm anything up.
I think you should inquire at a different dealer. If the truck is equipped with a remote fob from the factory for opening the doors and entry. Then all the dealer has to do is change out the fobs with ones that have the remote start button and do a reprogram on the bcm. pretty easy these days. Id call around a couple dealers. This should be a very straight forward and easy upgrade for any new vehicle. I know a few that have already had this done etc.
Funny you should say that.  I called Chevy and they are looking into the matter.
I was like” WTH” there is no way to install a remote starter? The local audio and electronics place says they do them all the time.
I’ll probably go there as the quoted price at Chevy ( before they couldn’t find a part) was the same price anyways.
Dont really trust having dealer do it now anyways. Lol
thanks for the reply.
UPDATE: Chevy calls me today and tells me the part # needed 22997090.(fob)
Before they called, I called another dealer who said no problem $605 to add.
Call my dealership back and he tells me " yes Chevy called and we were looking up a different part # but we can do it for $413. Aftermarket was $499
I will have the OEM installed.
Thank you to everybody on these forums for their inputs, Just have to dig to find answers and get things done.
Have a great day
Have a great day
It pays 0.5hrs book time right from GM on that.  The kit is $275.  Even if they are $100/hr they are still about $50+ high on that.  Our accessory rate is $80/hr at work, so $315 installed before tax.   Might want to check their pricing on that.  If you go to their website and see the accessory section, they should have a catalog that's hosted by GM with all the info and then the dealer's labor rate calculates an install price.
Unfortunately we have little choices to pick from. The one dealer was 2.5 hours away and charges $605 the one I bought the truck from is 50 minutes away and charges $413 the third one I wouldn’t deal with.
So that is what I have to pick from.
But thanks for all the info.
If your gonna spend money dont do it on the crappy oem unit.
I have a Viper 5706V 2-Way, Remote Start and Alarm.
All Doors, Hood and Tailgate, Shock and Tilt Sensor, Window Roll up and Down.
Wouldn't go any other way.
If you don’t mind me asking what was the installed price of that?
Viper was about $200, DB3 interface $40, Tilt sensor $20.
I did the install myself, so for under $300 it was a no brainer.
I've put this same setup on my trucks for years.
Back when I used to have a shop install them it was around $400 - $600 complete depending on where you go.
If your comfortable with wiring its not that hard at all, its all databus nowadays so very few wires to land.
I may be wrong here, but shouldn’t it work with Mylink app when installed?
That is what others with onstar are saying.
Not on here but locally.
Thanks. I am somewhat mechanically/electrically inclined, but I’m not real sure of myself doing one of these especially with a new rig. I figured the app will work with this. A friend says his does.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
