I am wanting to swap out my overhead console for one with HomeLink in it. Where can I come up with the parts diagram so I can get the correct part numbers?
I believe the wiring harness up to the console is the same in all versions (WT, LT, LTZ, ect). It is my understanding that the small harness inside the console is different depending on what package you have.
I have found this site http://www.gm-parts-dealer.com/2017-chevrolet-silverado_1500-ltz-flex_5.3_v_8-transmission_automatic_4-body_hardware-overhead_console-GH14528/ but it doesnt show the 2018.
Any help?
Thanks
Bill
Sent from my SM-G920V using Tapatalk
I found this part on this site
https://www.tascaparts.com/oem-parts/gm-console-assembly-23396113/?c=Zz1ib2R5JnM9b3ZlcmhlYWQtY29uc29sZSZpPUdIMTU1NjA1JnI9bGF5ZXJfMSZhPWNoZXZyb2xldCZvPXNpbHZlcmFkby0yNTAwLWhkJnk9MjAxNyZ0PXd0JmU9Ni0wbC12OC1mbGV4
It shows the console with work on a 2014, 2015, 2016, and 2017 all trim packages. Surely it will work on a 2018 since it is the last model year before the design change. I just cant find any documentation to prove it.
What do you think?
Bill
  • 4 months later...
Just completed this mod on my 2018 1500.  The sunglasses holder did change as well as the ambient lighting.  The part number for 2018 is 84083245.
Looks like it's been replaced by 84391067.  Is that everything needed to convert a non-homelink to homelink equipped?
Edited by Darmichar
I just put this one in my 2018. This new number is about $60 cheaper than the one it replaced.  Complete panel except air bag light, easily removed from the old one. Works great!
https://www.gmpartsdirect.com/oem-parts/gm-f-console-84391067
1 minute ago, billkater said:
So this number is for the "Homelink, No sunroof, No sliding rear window, in ash grey"?
Thanks
Yes that is it!
Yes that is it!
Great. Thank you
I just placed a order for one. How long did it take for yours to ship?
22 hours ago, billkater said:
Great. Thank you
My employer has a sister store that is a Buick GMC dealer. They ordered it for me and I had mine in about 2 days.
Just installed my new console. One problem. The new console was missing one 2 wire plug. It was plugged into a connector mounted to the right of the console under the headliner.
Any clue what it goes to? I didn't have time to try to trace it.
Auto dim mirror? Vanity light in sun visor mirror? (Not sure if I even have one). Or is it the side curtain airbag on passenger side?
Picture is the plug on the old console.
