Preventative Maintenance on High Mileage '14 Sierra 4x4 5.3L
All good advice.
I would do the transmission.  No worries there.  I've changed many with over 150k on them original miles with no issues.
You can move to a 5w but as stated no need and as far as protection, it will be the same. From all the UOA's i have done, the 0w-20 had protected just as well as a 5w-30.  Oil has come a long way.
One thing to watch for is the front diff.  I changed the fluid out of the front diff on my 2002 at 85k miles and afterwards it started leaking at the seals.  The gunk in the old fluid was keeping things sealed.
15 hours ago, Mike GMC said:
Well, if you land in the 18-20 range, I'd be happy with it.  I've also noticed that windy conditions can have big impacts on the mileage, positive or negative depending on direction.
One data collection service places fuel consumption for this combination around 17 mpg.  Oh yea. The effect his huge.
I've read stories on here about guys getting well over 20, even 25 mpg.  I've never been close to that.  I usually set the cruise at 80+ on the interstate and let her roll.  Even on the slower 2 lane highways at 65 ish, I barely see 20 mpg.
The difference between the former case and the latter is speed and wind. Funny thing about machines. They respond precisely to the inputs they are given in direct obedience to the laws of physics. The only creatures in the universe that seems to be amazed by this are the humans giving those inputs.  That amazement turns shared experiences into 'stories'.
On that transmission. Do a pan drop and change the filter as well. OEM or WIX. It's a six quart refill. Clean the pan. You have enough advise on what brand to use.
Anything after 60mph your mpg will drop. At 80, yours is dropping quite a bit. Physics...
I tried 55, 60, 65, 70 and 75 all on flat roads and each 5mph i increase the mpg dropped on the dash about 2-3 mpg. Not very scientific but it shows that faster you go, less mpg you will get.
Stories, reports, data etc are all the same to me until or unless it becomes personal experience.  I can't and won't try to drive slower because I like to drive fast way too much.  You only live once and I'm not going to make myself miserable to save a little bit  of gasoline.  Higher fuel costs is the price I pay and I'm good with that.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
