Oil Change Question
10 hours ago, Dr Awesome said:
I checked and that does not say that oil has the dexos1 Gen 2 certification on the site https://www.centerforqa.com/dexos-brand2015/, do you know why that is?  I can't imagine upholding the engine warranty if the cert isn't there, even if the oil is good.
AMSOIL doesn't pay GM to have them certify the oil.  It is an unnecessary cost. A very expensive one at that. It meets/exceeds the dexos 1 Gen 2 spec.  AMSOIL's own warranty will cover any repairs if the known cause is their oil.  If something should happen, first thing to do is take a sample of the oil and send it off to a lab of your choice to get analyzed.  If the oil shows that it was out of spec and cause the problem then AMSOIL will cover the cost of the repair.   Honestly, in all the years I have been with AMSOIL, I have yet to see where there was an oil related issue.
  • Replies 34
I only do cold oil checks after sitting over night.
The most accurate IMO.
K.I.S.S.
If you park in the same place all the time this is the way I see it.
You must be sure the right amount of oil was put in after an oil and filter change.
If you didn't do the oil change how do you know the right amount of oil was added?
When you do your first oil and filter change be sure the amount of oil is correct.
Park the vehicle in it's normal place.
Check it cold the next morning.
Remember where it reads on the dipstick.
You know it has the right amount of oil so this is your reverence mark as long as it's parked in the same spot.
Doesn't matter how level it is.
I parked on the street at our old house for 30 years.
My truck leaned to the passenger side due to the slope of the street.
I got my reference mark as I said after my first oil change and learned how much oil to add by checking it again after a cold check.
Just because they did not dance around the fire and sing praises to the Gods of GM does not mean the oil does not meet the specs.   GM Dexos is just a spec that has certain additive requirements. It is a documented standard in the automotive oil community.  Amsoil, like all the other blenders, gets their add packs from the same suppliers like Infineum or Lubrizol.  And they supply anyone who requests it the very same add pack that makes up Dexos as they do any other blender.  The blender mixes it up with the proper base oil and, voila!,  it is a Dexos rated oil.    And even if it isn't on the "approved" list, the Federal Trade Commission regulations about accuracy in labeling would make any blender liable if the oil did not meet the spec.  No reputable blender needs to have the fines or the associate marketing hit by blending up sub par stuff.
Every oil you see on a shelf, every oil you can order, etc are all blended from various components that come from various suppliers.  No brand makes its own complete motor oil.  Shell, Mobil, Schaeffer, Amsoil, Castrol, Supertech, whatever.... it is mixed up and packaged by the blender from stuff they get from other sources.  The blender might make one or two of the ingredients that goes into a motor oil, but no company makes all the components that go into a motor oil.
Your dipstick has 2 marks on it. The lower one is the "add" mark and the top one is the "full" mark, and the space in between is the operating range. If your oil level is in the operating range you are OK. I would think it would almost be impossible to get it exactly on the full mark, and keep it there for 5000 miles. If after checking it later on, say 1000 miles, the oil level is not in the operating range, either high or low, then you may have a problem.
IMO the brand of oil used is what ever brand makes you feel good. I think is like the gasoline we use...it's all made in the same place and just has different labels put on it.       :rolleyes:
  • 1 month later...
On 6/1/2018 at 3:17 PM, jbman said:
Would rather use 10- 30 weight I feel the 0-20 is just to thin. What say you all?
I have the 6.2L and run 5w30 mobil 1 EP or pennzoil platinum with confidence, GM and all oem's play the CAFE game to get best mpg. Look up the camaro and corvette (6.2L naturally aspirated) they both have the 6.2L v8 and they spec the 5w30 oil. The only thing different between the two is the intake manifold and tuning along with exhaust components that are not affected by oil use. Between the two truck lines GMC and Chevy they  sold just over 900,000 trucks last year, the corvette and camaro sold less than 100,000 of both, the CAFE standards "fuel savings" (that you will never notice) that drives them to use these thin oils and is why the spec them for one and not the other.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
