Lift Kit Help
4 minutes ago, adamj2121 said:
My truck was purchased as an ALC package, so I have never driven it without the lift. I have a FlexFuel engine and run e85 almost constantly. Running ethanol I get about 12-14mpg, depending on my driving style. I have seen as low as 10 with a lot of aggressive acceleration. When I have ran regular gasoline, which I do during the winter months, I get about 16-17 mpg. I had a Sierra 1500 as a loaner and I averaged 17-18 mpg in it. The biggest difference is highway driving anywhere that has a 70+ mph speed limit my truck will barely get above 18mpg where as a stock truck tends to get 20-21mpg. Overall, I don't notice the lower fuel economy that much and I am willing to trade off a couple of miles per gallon for the looks and ground clearance.
Thats not to much to sacrifice for an awesome looking truck.
  • Replies 66
10 minutes ago, jimmyboy8301 said:
Yes
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone w/ Bilstein and Fox
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
So why did you go with that combo? (Bilsteins in the front Fox in the rear)
The fox was offered as an option with Zone. Zone only offers spacers or full Coilovers , not just shocks with stock springs and i didn’t wanna shell out the money for full Coilovers and i heard great reviews about the bilsteins so it was a no brainer lol
I can't find that option on their website. Did you call them and order that way? All they have for options is a skid plate.5b16e349244c0_ScreenShot2018-06-05at2_21_44PM.thumb.png.93fe52d1d94931610b40dd2fc45b6901.png
Which option?
1 hour ago, jimmyboy8301 said:
Which option?
to replace the struts they have in the kit with bilsteins or Fox.
The fox shocks are a Zone option, the bilsteins are not. I bought them separately
I can't find where the Fox shocks are a Zone option.
8 minutes ago, jimmyboy8301 said:
http://zoneoffroad.com/fox-shox-2.0-adventure-series-shock/98450759
These
I'd have to buy those separate from the lift kit though. I could't find where they offer the Fox with the lift kit.
They used to, id give them a call bro
Okay, I was just checkin to make sure I wasn't missing anything. I appreciate the help.
No prob, glad to help
The Fox 2.0 Shocks (984-50-759) should work with the 4.5"CST lift kit?  These fox shocks are designated for Chevy/Sierra 1500's with 4-5" lift.  Now that CST makes their own shocks I can't get an answer from them other than them promoting their product.   The 4.5" CST lift kit comes with 3" blocks for the rear so I'm not sure if I'm looking at this right.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
