  • Replies 3.3k
Top Posters In This Topic
On 5/29/2025 at 2:43 PM, txab said:
It ain't an "either or" thing. Polite and honest can be mutually exclusive. I just haven's master it yet. Perhaps another 70 years or so and I get the hang of it.
  • Haha 1
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 830 Guests (See full list)
