6" steps for a 2016 2500hd with 6.6
Can someone help me find 6" stainless steps for my 2016 2500hd 6.6.  My son bought me a pair from amazon and they don't fit because of the def tank. Would prefer something off of eBay or Amaon  if possible as I don't want to spend $500. Thanks in advance
3 hours ago, Waaazooo said:
Like the stock ones?
Yes
You want to spend 500 because the cheap ones are JUNK....
Look at GMparts.com
The OEM ones are the best. You might find some take off ones on this site, check classified.
2 hours ago, Big Whiskey said:
I've got a brand new set of these still in the box, in my garage: https://www.gmpartsdirect.com/oem-parts/gm-assist-steps-4-round-chrome-22805436
I'd make you a sweet deal, if you're interested in driving to central Illinois, haha.
Are these the single or the ones that cover both doors on a crew cab? The link is for a single cab.
If they are the crew can ones which it appears when I looked them up I will be interested in getting them from you
Sorry, they're for a crew cab.
I'm looking for them for my crew cab. Pm me a price?
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
