Bucket seat console organization
Welcome to this forum and congratulations on your new truck!  Pictures are always appreciated!  My tip for organizing your console is to not look for things to store. Essential items will soon become obvious.  Regularly clear out items you no longer need or use.  Don't let it turn into a junk drawer.
There are a bunch of different organizers on the market.  GM makes 2 different ones or there are a ton of aftermarket ones on ebay and Amazon.  If you use the Search field in the upper right you will also find a bunch of threads on here with pictures.
