2 hours ago, Whiz said:
Been that route with two GM dealers here, and no one can give me the exact part numbers I need.  I've been told 8.25/8.6, and now a few minutes ago 4 Wheel Parts Inc says GM used the 9.5 and 8.25 "since 2006".
Am a bit gun shy to order in a set for ft & rr a=nly to have it on the hoist with incorrect size(s).
I'll keep checking and, if possible, tap a GM tech with GM whose know EXACTLY what is needed.
I worked in a GM parts department many years ago my senior year of college,  so I know that one can be wrong particularly with a brand new body style and thre rumors that GM is now using a proprietary front differential.
Have you tried talking to a place like East Coast Gear Supply? There's always a chance that they have information on the 2019 axles. Make sure you have a way to take care of the speedometer/ABS issues that will come up after you re-gear.
Thanks, I will give them a call on Monday.
I have programmers for all my Chevy's, so recalibration of speedo is not a problem, but wise words for other who may consider similar options.
Which transmission and axle ratio should I get if I want to lift it and put 35" tires on it (without changing the axle ratio)? I'm assuming these calculations are with standard tire sizes.
Thanks
You don’t need the max tow. I have a 2019 RST with a BDS 6” and 35” ATZ and I can still burn em down. Power loss is minimal but I don’t tow with this truck. I have the 8L90 and 3.23 and I have no regrets. 97ebd515c84d4e81569ea8ea0c8d04e1.jpg
Thanks for the info.
if you want to run a 35 tire, you need 3.73 rear gears at minimum, and 4.10 at best
You shouldn’t spread misinformation. People get hung up on gear ratios and not the final drive. Yes 3.73 was necessary when we had 6 speed transmissions.
We now have advanced 8 speeds and air conditioning....no need for 3.73 gears. Why do you think the max tow comes with 3.42? Look at the charts.
well  6spd vs 8 speed 1-2 forward gears... are almost identical 3.72vs 3.42. but still torque gain is far better with a 3.72 in the 8speed , better off the line stop and go city driving with 35" tires
Edited by flyingfool
what's the difference in 6spd vs 8 speed 1-2 forward gears... ?
Go to the top of this thread and look at the charts. That information can be and has been confirmed by GM.
Is there any way to tell what ratio a truck has besides the build sheet or what salesman says? They don't put the rpo codes in glove box anymore? Or whether it has the max trailing package? Thanks
RPO is in the drivers door now
  • 11 months later...
Seems like this thread died but I’m trying to revive it, I have a 2020 6.2 with 10 speed but trying to wrap my head because I’m in love with the 37x13.5 wheels and tires and hoping the 10 speed behind the 6.2 will help the 37’s especially since I tow!?!?!?
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
