2018 Silverado Gas Cap.... !!??!!
Danka
We have owned a capless vehicle since around 2011, never had any issues with them in regards to water or dust. The OP acts like water just comes shooting past the edges of the of the fuel door and right into the opening for the fuel pump. I have never had any water on the entrance to mine nor any dust. As said there are 2 doors, one external that is sealed and one internal down inside of the filler neck that is sealed. Nothing is going to get into the system at all.
  • Replies 34
3 hours ago, Nick The Great said:
There's states that don't have the trigger lock on the pump?  I've fueled up vehicles in probably 15 states and never seen that.  :confused:
There’s pumps in Iowa that don’t have locks on them (you must be living a sheltered life at the gas stations anyway)
LOL I suppose so.  I must only frequent the fancy-pantsy gas stations :smash:
As soon as I read the first line I knew you were an engineer....which means lots of theory but lacking understanding of real world implementations.  The fuel line is still protected by two seperate flaps that essentially act like a backflow prevention valve in plumbing.  Not to mention this is a proven method over years of implementation.  So what I am saying is you are wrong.  End of story NUFF SAID.  Except that I have been a plumber/gasfitter/pipefitter with real world experience in this concept.
Let’s see, I don’t like cylinder deactivation, CVT transmission, small turbo engines, most of the nannies on new vehicles and cap less gas caps. It’s possible the Camry I bought a year ago may be the first new vehicle I keep more than two years.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
