my 2014 chevy silverado will chirp every time it switches from v4 to v8.  I was reading that there may be a fix for this.  my truck has 40k miles on it and just out of warranty.  Will gm do anything for this since it is happening to thousands of trucks of all different years?
There is a tsb for it so they should. But I also have had the "fix" twice now. The new design doesn't chirp as much but it rattles loudly at idle. The old design you have has two square knobs. My advice would be to bolt it open and be done with it. The new design is not that easy to bolt the flapper open, but you would also be getting a new exhaust so that would be good I guess.
Pretty typical of the Exhaust Adaptive or "flapper valve"  just behind the muffler.
Mine use to chirp also during V4 to V8 and also on warm startups. Thought it was my starter.
Some here have reported GM replacing entire exhaust under warranty.
Option 2 is to clamp the valve open or try to lubricate the heck out of it.
But if i clamp it open i have heard that it can do damage to engine.  Is this a true?
My flapper valve started chirping / squeaking during V4 / V8 transfer at 1500 miles..
Dealership replaced entire exhaust system with new style valve assembly..
Unfortunately, with 40K on truck,, chances are they will not replace,, by give it a try anyway,, nothing to lose...
As others have stated,, either lock it open or just remove..
May be time for exhaust upgrade to better / nice sounding system..
Cheers---K
Just went today to my GMC dealership that sold me my 2015 Sierra last month for this chirping issue. They told me there is a new exhaust system for the 2015’s that will solve this flapper problem. Being under warranty still I will have it replaced within the next few weeks. I also told them there seems to be more vibration in the pedals while in motion than my 2004 model made. They told me the new suspensions are tighter and that there is more vibration felt in the newer models. So it seems newer isn’t always better in all aspects.
Had my 2015 looked at last week for the valve chirp but since I’m 6 months out of the 3/36 bumper to bumper warranty, they wouldn’t replace it no charge. It’s not covered under the 5 year power train warranty. I was quoted $800 for the new exhaust. Figured I’ll clamp it open or put the $800 towards a borla/Corsa exhaust.
Clamp it open and save the cash.
Sounds better clamped open.
A little droning here and there but not real noticeable.
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
