Anyone here have issues with STOCK tires/wheels rubbing the UCA?  I was rotating the tires yesterday and noticed what pretty clearly looked to be like tire rub marks on the UCA. This seems odd considering everything is completely stock with no modifications.  Anyone else notice this ever?   This is with a 2017 with the stamped steel control arms.
I didn't think to get any pictures but next time I have the wheel off I'll snap a few pics. Not sure what else this could be.
Edited by reardiff
Do you have 18" or 20" wheels? I have a 1.5" level and it rubs pretty good on the control arms, I didn't pay attention to whether it did before the level.
Sent from my Pixel 2 XL using Tapatalk
Johnny01: I had this problem on my 2016 chevy Silverado 1500 after I installed a 2.5" leveling kit. But not before. I ended up installing Borla wheel spacers to solve the issue.
Stock 20 inch wheels with 275/55/20 stock tires, no level or any other modifications. Just seems really odd being it's 100% bone stock truck. It's been since April since it has been in for an oil change and last time the wheels were off so seems unlikely it could be anything else.   Now I am very hesitant to go up to a 275/60/20 with a 2 inch level if it rubs already I'm guessing it will even then but worse.
I have r65's on a 2014 sierra 1500 and the 2.5 lift kit. Barley rubs when the wheels are cranked all the way.
I have then same wheels/tires on my 2017.  I installed a RC 2" level and began to experience UCA rubbing at full lock and plus it rode like shat (stiff on the front).  So, I removed the level.  The level kit helped at some kids' sporting events I had to go to, where there's never enough parking, and allowed me to park up on the curb side along with all the other trucks.  However, this is my DD so I just decided out of practicality to put it back and keep it stock for now.  I'm getting great gas mileage and its a comfortable ride.
Yes, the stock 2018 chevy and gmc models that I have checked (5) have slight rub marks on the UCA and the sway bar. I noticed before I put my level kit. now of course it rubs a bit more.
Curious why it would rub more with a level kit, one would think that would make it rub less?   I wonder if replacement UCA's would be any different?
  • 5 months later...
I went to replace the standard stock tires on my 2018 GMC Sierra yesterday after 42,000 miles. Yup, guess what, I too have rubbing on both sides. Put original tires back on and drove to GMC dealership where I purchased the vehicle. Service shop wanted to blame it on my alignment being out when looking at the tire tread was pretty even. He wanted to charge me $100 to re-align the truck. I told him the only way I would pay for alignment was if it corrected the issue...... tire rubbing on the upper A frame. I said; " you align the front end and if the tires do not touch afterwards..... I pay and problem fixed. However, if tire is still rubbing I'm not paying". He declined.
I left and found my salesman in his office. He was floored that his Service manager did not take my offer to pay if the problem was fixed! Salesman agreed to pay for the alignment to determine if it actually would fix the issue. After re-alignment......... tires still rubbing.
They (GMC) are negligent in design and not wanting to fix their design flaw. Now, I have to purchase new tires ($1100-$1200) that will run the inside of there tire........ dangerous!
Is there any litigation going???
Yup, my '17 with 20" factory wheels and tires rubbed on the UCA. I just put a 1.5" leveling kit on, don't know if it will make it worse or not. If it becomes a problem, I will look into spacers.
with a level kit, tire rub will increase ever so slightly.  Especially if you go with a wider tire.  For me I did a 2" level kit and changed to 285/55r20 tires.  This change did increase the tire rub on the upper control arms slightly over stock.  1 1/2" wheel spacers fixed that right up & stance is so much nicer now.
anyone have a 17" work truck rim  to see how it rubs with a leveling kit?  Now you guys want to make me look at my 18 haha. I never hear anything weird when turning even full lock...
checked my 18 today, stock 18" rims and tires with a ZONE 2.25" leveling kit. pics are at full lock and both sides are equal. Looks like it has plenty of space but maybe at full lock it comes close - its a bit over 1/2" space-3/4"
dont mind the dirt
I've got 2.25" level up front, and 275/60/20's now and i'm rubbing the UCA's as well, and looking at wheel spacers - Steve, what brand of spacers did you get?
G2 Axle & Gear. Got 'em at Summit Racing.  quality CNC'd hub-centric billet aluminum spacers.
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
