Once I get home from work, I’ll get OEM part numbers for the modules. Keep in mind that this is not a simple buy a harness and plug and tow. Could you acquire a harness from a salvage yard, yes you could but then you a lot more to sort out cause as with JL1, if you have park assist sensors, the the rear camera, the magnaride suspension and so on, you’d have to get a harness from a truck that has all the same RPO’s as your truck with JL1 cause those wires would for those options would be present in the harness.
Edited by C. White
Even with adding the additional modules, the switch, the wiring additions (which will be significant and likely insurmountable for those that are thinking just add the switch and go) there is still the programming that will likely be impossible to resolve.
To date - this is still IMPOSSIBLE.
TLDR...GM's TSB still applies and it can't be added.
$100-200 aftermarket controller beats the absolute a$$ache you've presented.
Edited by newdude
No, because GM still doesn't sell the programming update that allows it to work for trucks that didn't come with it from the factory.
  • Sad 1
More than just programming.
Wiring (different chassis harnesses with and without JL1 brake controller), modules, programming.
Sure, but you can add all the physical stuff, wiring, switches, computer, relay, etc, the thing that stops it is the programming.
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 756 Guests (See full list)
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
