Reviews of 6.2 Maxtow towing 10k
avalonandl
I have a 2015 Duramax 2500 which I purchased in 6/14. Love the truck, not crazy about the ride here in pothole country (Michigan).
I am curious about how people who have the 6.2 Maxtow package does towing 10,000 lbs. I have a 35 ft Donzi Center Console I tow occasionally. Might consider swapping out to a 6.2 MaxTow (not the 5.3). I know the 6.2 has great power/torque...
I am asking specifically Maxtow owners here to chime in about how their tucks handle BIG tow loads... Braking, handling etc.
Thank you in advance......
Real world experience. I tow a 8000 lb 5th wheel.  Using an Anderson Ultimate Hitch ( 42 lbs).  I have towed all over nw and all thru west coast and spend time in Arizona in the winter and it works great.  Never a problem and will get 10 mpg towing and I love it.  Since 90% of the time it is used as a DD a 3/4 ton was not considered.  I do have disc brakes on rv which makes all the difference but more of an afterthought then necessity but will never have another rv without them.  It tows straight and have been in some severe windstorms but have never  had a “ white knuckle” tow. Only added air bags to level but didn’t really need them.  It works great for my application.
Thank you Bigmac. I appreciate your comments.
I probably will keep my Duramax. For one I probably would take a bath $ wise. I would want one with the 10 speed trans.
I just wanted to say hello neighbor! I am right next door in Rochester Hills. Small world.
Keeping the Duramax seems like a good idea since you already have it.  Sorry I have no additional inputs, I haven't really towed heavy with my 6.2 MaxTow.
This summer i pulled a 10K+ forest river 2715 toy hauler from Phoenix Arizona to Warren MI via Tennessee and back ~5500 miles. as was already said no problems for the truck. The engine makes plenty O power and the 8 speed kicks down as needed to pull up hills and the engine braking assist going down is very handy. It was quite windy most of the way which made for some interesting sensations at times but the drive didn't phase the truck. A good anti sway hitch setup and airbags to support the load is recommended. I have Michelin road tires, Eibach swaybars and Sumo springs that helped stabilize. Worst part hauling that load were the expansion joints at quite a few overpasses. They tend to dip heavily sometimes.
Ski Doo- Thanks. I see you have an Avalanche in your AVATAR.  I used to have a 2500 Avalanche, loved it.
Ah yes with the 8.1L I think it was?   Must have been pretty beastly!  Mine was just a half ton Z71.  It was a great truck, I loved mine as well.
Yes it had 8.1 and 4.10 axles.... was a beast. I put a Hypertech tune and a Flowmaster 2in 2 out muffler and it had a DEEP tone. Not to loud but a rumble. 11.5 mpg..... oh well
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
