how to remove snow & slush out of rear bumper?
I know, we're still 2 months away from any real snow even in the upper Midwest. I'm temporarily in a rental with a small garage. The only way I can get my truck in the garage is to back it all the way up to the wall. I'm dreading the inevitable melting slush dripping out of the bumper cavity all winter.
When the roads are really bad, I usually walk around and clear out the wheel wells with a brush before parking. But I can't get it all out of the bumper. With this small garage, my wife and kids will be walking through the crud right next to the door into the house, not to mention it will probably be soaking into the wall, which will be 2" away from the bumper. Does anyone have any bright ideas to keep the slush from building up inside the rear bumper? or a good tool to scrape it out of there? the snow brushes I have don't really fit and I don't want to scratch everything up either.
Just wondering if someone has come up with a solution to this minor inconvenience :D
Fender liners and mud flaps are the best solution to me.
Nobody makes a rear mud flap that prevents rear bumper buildup that I know of.
I built some for my old truck but haven't for my 2012. They stopped the mess but weren't pretty.
Would keeping your truck in the driveway be an option?  I know it means sweeping the snow off your truck in the morning but dealing with the crud(and my wife) in the garage would be worse in my situation.
23 minutes ago, Bushleaguechew said:
Pull in forwards.
If only.... I can't do that, due to the width of the garage, I can only back in so that I can turn the front wheels to fit inside and get out of the truck. The passenger door will be tight to the wall. Its a small garage. I'm desperate to park the truck inside during winter. It is currently living outside.
It might come to that. I'd prefer to park inside, but if I can't make enough space to avoid wife and kids dinging doors, then it will stay outside. This garage is barely big enough for 2 sedans.
Gatorback mud flaps are a pricey alternative. I put them on to keep slush from flying onto my running boards from the front wheels. Never really paid attention to the rear but they keep my truck way cleaner in the winter time. They’re significantly longer than the oem plastic ones. These are the only pics I have right now. 38689bb78a7deb0d466746c9173f4acb.jpgb3b791d7418c82bb6ac94f8a90c9da9a.jpg
Move South problem solved...
I was toying with the idea on my 3/4 ton of removable rear flaps attached to the frame. Trucker flaps( thick long rubber ones at the farm store) cut to fit, air hose male end welded to flat bar stock bolted/clamped to frame, female end welded to solid round rod to attach flap. The thought here was so I could mount it higher in the well and stick out farther when plowing. Haven’t looked to see if there would be room in the wheel well for it to work on a 1/2 ton?
Since you have the chrome bumper I wonder if you can find a way to wire up a heated cable to it (magnets maybe?) plug it in let the crap melt then put the truck in the garage. I use one on my water well head to keep the pressure switch from freezing.
Don’t know how much room you got at your rental but I see those portable type plastic shed/garage things listed on Craigslist from time to time for cheap some of them are descent made and will handle a snow load, also seen people giving away car ports on there if a guy could figure out how to temporarily attach it to the earth and use plywood for walls. If nothing else it will make the neighbors that much more happier when you done do move out.
BTW THANKS for reminding me how much I love winter...
I have a 3 car garage that would fit 4 if empty and I still park outside.  With kids and a garage as small as yours I would be way more concerned about damage to the truck and being outside sounds safer.
I have mud flaps on mine and have not seen my first winter yet.  Is it really that bad?
That bad? It depends on the temperature of your garage and your tolerance for walking through slop.
If you drive on roads that have been salted after decent snow, the slush cakes in there. There is always a trail of dripping crud out of the rear bumper. Is it any worse than the regular wheelwells of our other two vehicles? not really. But the difference is I can walk around and clear out most of the crud with my foot or a snow brush on the other vehicles. I can't access the slush under the truck bumper.
Step 1: Go to Home Depot/Lowes and buy a few cans of expandable spray foam
Step 2: Remove bumper
Step 3: Build junction boxes for access to license plate lights and/if you have sensors
Step 4: Fill bumper with expandable spray foam
Step 5: Install access covers for lighting/sensors
Step 6: Re-install bumper
Step 7: Drink a beer and admire your work and to celebrate no more snow in your rear bumper
1 hour ago, rrmccabe said:
And this is the truck with the blade ?
yup.
I only plow for myself. This winter it is staying in Grandpa's shed.
Next year when we have the new house, I'll have a big enough garage, that I won't care about dripping crud after I plow.
Nicks all purpose cleaner and a pressure washer.  Clay and seal the surface prior to snow which will make it easier
    MASONV88888888
    MASONV88888888
  • Who's Online   0 Members, 0 Anonymous, 1,580 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
