I too had a 2015 Silverado with which you could not see very far when on low beam, I used to cuss the ones who's dims looked like brights. Now that I have a 2019 I feel that it's like payback. I do get flashed on occasion, just flash them back and go on my merry way, one of these days it will be a trooper and I'll wish I hadn't flashed them. (lol)
  • 1 year later...
Guess I'm late joining into this conversation, however.....  Just bought a 2019 Silverado LTZ Z71.   I am not overly impressed with the headlight performance.  The low beam is adequate. The high beam doesn't provide much further visibility than the low beam does.  In fact I have driven home (20 miles / 32 Km) on a dark night, with my high beams on to test them, and not 1 car flashed at me.... none of them...  and typically if your fog lights aren't on, people flash....   the fog lights seem to be the only indicator to many that high beams aren't in use.  I don't have that problem at all.....    With lonely dark rural roads, I want spectacular high beams to see the deer well in advance.  My previous trucks (2015 Silverado and 2007 Colorado) both had amazing headlight performance.    Wondering if that is the difference between HID and LED performance.  Anyone else experiencing this?
I have the same problem. The light settings are fine, it’s just that the headlights throw more white light than other vehicles. Only way to fix it is change out lights, and that isn’t going to happen for me. You know what I mean, I am now that guy who has those F**kn white lights coming towards me. I like the coverage I get from those headlights though, I just have to put up with people flashing their lights though.
Edited by Gray
  • 1 year later...
On 10/25/2018 at 3:01 PM, dphel27 said:
Update:
I dropped my truck into the dealer this morning to have him look at the void line in the headlights. I followed up with the dealership and the service manger told me the headlights were adjusted perfectly. He also said that he test drove a couple other 19 Chevys in the dark this morning and they all had the same void line as mine. The dealer is waiting to hear back from Chevy. I'm sure they will say it's normal just like the stress marks on my door panels that look like dents. :rolleyes:
Thanks for all your help
Must still be under warranty, wait till it's off and take it back for a quote/adjustment, it'll need it then I'm sure..
(just kidding, dealerships would never do that)
    • HM oils and cleaning. Well, soft deposits yes, perhaps. Like you say esters are present in in theory that should be a plus. But, is there enough? 🤔 The marker is the "Aniline Point" and it has to be pretty low to solve out baked on deposits. The softer sludge, yea, they do that and that is the claim. Valvoline R&P is the only HM oil I know of (Jury is out on Mobil 1's product) whose chemistry is uniquely able to remove the hard stuff and not be so aggressive as to swell seals to uselessness.    Oxidation levels in virgin oils blends is a good indicator of ester level and higher is generally a lower Aniline number and at one time we could predict without the $400 aniline test it's effectiveness. AN's, alkylated naphthalene doesn't show up in the oxidation test but does show in the aniline test and has become sort of a cheaper go to but most oils only add enough to solve the additive package. Not nearly enough to clean the harder carbon materials.   To your second question about does it matter. Yes is the short answer. Deposits are insulative. Those under the piston crown for example add octane requirement for knock free running. We don't' normally notice in todays motors due to Knock sensor driven ignition R-e-t-a-r-d. At least until the full slate of available values is consumed. Newer motors also often use oil jets to cool the piston to achieve tunes that would otherwise not be possible. Deposits on either side subtract from that. Deposits in fine screens used in VVT/VVL or DFM/AFM services live and die on cleanliness and screens are front and center. Vacuum pumps as well like brake booster in the K2's.    90% of todays oils are Group II+/III blends. A few more at PAO/AN/Group II's. A few boutique oils not Walmart shelf materials have enough solvency to prevent but not remove the hard stuff. R & P the current exception. Even HPL's EC30/40 used as directed (20% max) will get the soft stuff and some varnish out but not the hard stuff.    That orange varnish isn't baked on oil. Those are fuel varnishes left when the fuel diluted in the oil drops out when the oil cools. Like sugar does in a saturated mix of sugar and water that is put into the frig. That is ring sticking material and a glue the binds hard carbon sometimes.    Name brand shelf oils are intended to provide a useful service life at the least cost and highest benefit to the OEM who is trying very hard to keep you in $500 a month payment programs where the real money is made.   Did I miss anything you asked or left unsatisfied?
    • Yes, I understand. And I was saying (poorly), that it popped up on the DIC when I didn't have that info screen up. Just like you, but for a different maintenance issue. And just like yours mine didn't need to be shown at that time.
    • Ugh, amateurs.   But I did learn HM seal conditioners are esters.   I'm curious about deposit removal - some of the HM oils claim they really clean stuff up, the old and hard to reach stuff, and that's great? To Grumpy's point, a good oil should already be keeping the house pretty clean. I assume there are hard to reach places (underside of pistons?) and things that just accumulate baked-on oil and combustion vapors. If the deposits aren't friction or combustion surfaces and the deposit is just normal "seasoning", is it actually important to remove it?
    • You ask. The answer is yes. I think the strategy is brilliant. Or do you like more death and destruction? Gas is going down here. Maybe you need to change who you elect. Quit with the ridiculous statements or questions. You won’t get these answers.
    • Kicking off the weekend with $5.06 at the Kroger for 87. Are we great, yet?
