I’ve got a 19 LTZ and have noticed a few people have flashed their lights at me while driving at night while I have the normal beams on. Overall the lights are very bright. I’m wondering if the normal beam leds may be adjusted to high from the factory. I have attached a picture of the led headlights at night. I have an arrow pointing to what appears to be a dark line in the light output. Is this normal? My thoughts were if the lights were adjusted down a bit the dark line may go away. Thoughts?
Thanks,
Dan
With your fog lights off, is the dark line still there?  I'm thinking that's the breakpoint between the fogs and the headlights.  I could be wrong though.
Quote
Headlamp Aiming
Headlamp aiming is done with the low beam lamps. The high beam lamps will be correctly aimed if the low beam lamps are aimed properly.
Screen Method for Headlamp Aiming (Visual Aim)
The screen method requires an area set up specifically for headlamp aim.
The area should consist of a level surface large enough to allow for a vehicle and an additional 7.62 m (25 ft) as measured from the face of the headlamps to the aiming screen.
The screen should be a wall or other flat surface at least 1.52 m (5 ft) high by 3.66 m (12 ft) wide with a matte white surface well shaded from extraneous light, and 90 degrees to the floor. The screen should be provided with a permanent vertical reference line 0.61 m (2 ft) from the left edge of the screen, 2 laterally adjustable vertical tapes, and one vertically adjustable horizontal tape.
After the aiming screen has been set up and located, paint or tape a reference line on the floor 15.24 m (50 ft) from the vertical reference line on the screen. This line should be perpendicular to the aiming screen and a mark placed at 7.62 m (25 ft) from the screen.
Headlamp Aiming Procedure
  1. Align the left tires of the vehicle with the reference line extending from the screen with the headlamps aligned with the reference line.
  2. Remove any snow, ice or mud from the vehicle.
  3. The vehicle should be fully assembled and all other work stopped while the headlamp aiming is being done.
  4. The vehicle should contain cargo or be loaded to represent normal vehicle use.
  5. Tires should be properly inflated.
  6. Rock the vehicle to stabilize the suspension.
  7. Measure from the floor to the center of the lamp bulb on the vehicle. Some lamps have an aim dot marked on the lens.
  8. At the screen, measure from the floor and place the horizontal tape at the measured distance.
  9. Measure from the reference line on the floor to the left headlamp bulb centerline (1).
  10. At the screen, measure from the reference line and place the vertical tape at the measured distance  (2).
  11. Measure from the reference line on the floor to the right headlamp bulb centerline.
  12. At the screen, measure from the reference line and place the vertical tape at the measured distance.
  13. Turn the headlamps ON.
  14. Block the light from projecting onto the screen from the passenger side headlamp. This will allow the cutoff in the beam pattern from the drivers side to be more pronounced for easier aim verification.
  15. Important: DO NOT cover the headlamp, this may cause excessive heat build up.
  16. On this vehicle you will be verifying the aim of the vertical cutoff on the right side of the lamp vertical bulb centerline as it is projected onto the aim board.
  17. If the location of the cutoff projected onto the board differs from figure 4 then an adjustment to the beam pattern location is necessary.
  18. Adjust the vertical headlamp adjustment screw until the Right Gradient Line (Cutoff Line) is set at the Horizontal Axis within +/- 2.0 inches (2) measured at 7.62 m (25 ft).
  19. Verify proper aim location.
  20. Repeat the aiming procedure for the passengers side headlamp while blocking the light from projecting onto the screen from the drivers side headlamp.
  1.
1 hour ago, Brianibew said:
It looks like you have your high beams on from the picture.
Auto high beams?
Do you have factory tires and suspension? or have you added a leveling kit? changed rear suspension at all? driving with weight in the bed?
Easy way to tell is to face a flat wall (garage door) from 25 feet away while on level ground. Measure height of headlights above ground. Then go to the wall and measure the height of the cutoff line. If the cutoff line is close to the same height, that's your problem. I think its supposed to be 2" lower.
Everything on the truck is factory. The black line is still present when I have the low beams on with the fog lights off. The black line remains there when I turn the fog and high beams on. Which makes me think that an adjustment for the low beam lights may correct the black line.
I have attached a picture with a circle around what appears to be the headlamp adjustment screw. Can anyone clarify if this is the correct adjustment screw? Also does adjusting this screw only adjust the low beam headlamps?
Thanks,
Dan
Edited by dphel27
Thanks,
Dan
That would be the adjuster.  Adjusting the lows will adjust the highs.  Second sentence above in my other post from GM makes note of such.
Good chance the adjustment can be done under warranty as I see a labor op for it.
Edited by newdude
Thank you.
I wish i had that trouble with people pissed off and flashing my awesome headlights. Instead i have a 2014 with headlights that can barley illuminate 10 feet in front of my truck!
I recently got back from a long trip with my new 2018 Sierra.  With the tongue weight of my small trailer, and a bed full of gear, there was probably around 500 lb of weight bringing the rear of the truck down a bit.  I was getting flashed a ton by other drivers at night, especially by truck drivers.  It was very annoying.  Completely unloaded, I find the stock headlight adjustment a little low for my liking, but I have not changed the adjustment.
I get flashed a fair bit in my wife's Mini Countryman as well, with its stock HIDs at the original adjustment level.
My point is, that even with stock headlights, and factory adjustment, if your vehicle has bright headlights, some drivers are going to be flashing you.
Edited by rkj__
The factory low beams are exactly the same brightness as the high beams if someone is viewing from below the "cutoff line". So if you were annoyed by several people flashing you, imagine how EVERY OTHER driver on the road felt when you were blasting bright light into their eyes.
I know its not worth adjusting your lights for one trip with the trailer, but if you know your lights are pointing up and others are bothered by it, you have no right to complain about getting flashed. I hope you were at least smart enough to leave a large gap when following anyone. I hate when trucks get up behind me with their lights in my mirrors and I can see the shadow of my car in front of me.
Every time I am flashed in my Sierra, I hit them back with my High Beams. :thumbs:
I have also had people in front of me pull over and let me pass or I see them reach up and push their dimming lever on the rear view mirror :loser:
you're so cool.
FYI, if people are flashing you, its because their eyes are below your cut-off line. So they are already receiving the full force of your headlights,even while you are using your low beams. By flashing the high beams, you are only shooting more light up into the sky. Try standing in front of your truck, with your eyes below the cut-off, while someone else flashes you.
The 2019 Rams are the same way...  I think the newer trucks just have such good coverage people think the high beams are on.
Update:
I dropped my truck into the dealer this morning to have him look at the void line in the headlights. I followed up with the dealership and the service manger told me the headlights were adjusted perfectly. He also said that he test drove a couple other 19 Chevys in the dark this morning and they all had the same void line as mine. The dealer is waiting to hear back from Chevy. I'm sure they will say it's normal just like the stress marks on my door panels that look like dents. :rolleyes:
Thanks for all your help
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
