SES Light, Bad Gas causing p0325 on new Silverado??
Ry363
So this is second time ses light has came on. Says it’s p0325 code (have hypertech programmer) 2018 Silverado 5.3 with only 5,000 miles on the truck now. First happened about 2 months ago on the high way just after I put it to the floor for a few seconds. Think that was on my first tank of shell 87. Anyways, cleared the code and been running chevron 87 until yesterday I filled back up at the same shell, and on my way home from work same thing. Got on the gas and light came on. I would of taken truck into dealer but I have the hypertech installed. Only way to uninstall it you have to clear the code.
Done some research saying it’s better to run 89? Is it a combination of hypertech and maybe the gas at my local shell station? For months now that shell has only carried 87 and it’s also cheaper than any other shell around. What’s your thoughts? Thanks
She’ll is one of the worst gases out there, so I have been told. I have a Diablew tune and have been instructed to run only top tier gas from top tier gas stations. Anytime I run she’ll in my truck, regardless of octane, I get a bad spark knock. When I put Mobil, Marathon, Casey’s, Phillips or so on in she runs fine. I do run 89 octane when available though. My truck doesn’t seem to like the 87 much. I also run a bottle of HEAT in the tank every three or four fill ups too.
Before we moved to a small town in the mountains of Colorado I used Costco gasoline exclusively, Top Tier gas.
Costco puts more fuel system cleaners in their gas than the gov. standard.
In 2 years never had an issue.
The local gas station here in the mountains is a Shell station and Top Tier they say.
After about a year of using this gas my truck on a cold start would run really rough for a while.
It also seemed sluggish.
Two treatments with Sea Foam and it was OK.
Here in Colorado our gas is 85, 87, and 91 octane.
They say that due to our altitude higher octane fuel has no advantage.
I ran 85 at Costco and 85 at the Shell at first.
The manual says to run 87.
I have used thousands of gallons of 85 octane in our vehicles over the years without any issues until recently with Shell gas.
Thanks for the replies guys. Going to run the rest of this Shell gas and fill up else where, and reinstall the hypertech. Also going to try 89 or 91 see if it makes any difference with this truck.
Hi, Ryan. Hope your Silverado is running smoothly. Otherwise, feel free to send me a private message, if you’re considering visiting your servicing GM dealership. Thanks!
Anthony J.
I run Philip 66, 89 or Sunoco 89 pretty exclusively in the 16 months/25k I’ve owned my 5.3.
I will on occasion fill with 93 if my Sunoco grocery store gas discount card gets up to .30/.40 a gallon discount.
I know 87 is the minimum octane, but she seemed a little peppier when I ran mid grade on my first fill up, so that’s what I’ve been using since day 1.
All fuels in my area are E10
I throw a bottle of Lucus injector cleaner in the tank at every oil change.
No fuel related problems so far.
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,139 Guests (See full list)
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
