Sorry.... I just realized you posted that before. Been a long week!
I not sure where to look for the BCM connector, can you help me out?
White connector under your dash. Driver's side.
It's where the green wire is going into.
1 row of pins. 3 Over. It's one of the two gray wires in this connector.
Sent from my SM-N960U1 using Tapatalk
On 12/5/2018 at 11:27 AM, 1FUNC5 said:
 Has anyone had the issue of this power source cutting off and back on when the truck cranks from auto stop start ??????
I am, I was wondering why my dash cam was cutting on and off, it doesn't happen every time though.
  • 2 months later...
Hoping you might be able to help.
I have the same Opt 7 kit as you.  I have a spade powering it and connected to the open prong next to the 50.  That works fine.
I ran the aux wire from the Opt7 control box to the grey wire in the BCM and T tapped into it as I want the lights to power on and off with dome.
I have everything connected and grounded properly, but can’t get the dome feature to power on and off with this kit.
what am I missing?  Do I need a different power source since this one is switched.  Super frustrated.
  • 4 weeks later...
3 hours ago, Saloonwarrior said:
You mentioned  adding relays for your footwell leds. Is it really necessary with such low current draw?
I still can’t get them to come on and off with the door.  I’ve tried everything.   I have to manually switch them off as they come on every time when I open the door.
I just bought the Opt7 kit. Did you ever figure out how to get it on/off with the domes? I definitely want it coming on when I open the doors but don’t want them on all the time while driving
On 2/1/2020 at 10:04 AM, JAshworth03 said:
I still can’t figured it out.  Mine stay on and I use the remote to turn off.
I'm lost. I have the Opt7 kit fully wired in. Connected the accessory wire to the grey wire (dome light) on the driver side. I tried every spade connector on the passenger fuse box. There's one that's RAP and a few others that are always hot. I want the lights to come on when I open the door or the dome light comes on. With the RAP power, it only comes on if the vehicle is on. With the always hot connections, the lights stay on constantly. There has to be a spot in the fuse box that's door/dome activated... I love the lights but I need a way for them to come on with the dome/door without running all of the power off of that 24 gauge grey wire on the plug...
Exact same boat!!!
  • Sad 1
Yes i have as well, only with my Roof mounted dvd player i installed. my radar detector doesnt shut of thou, so its probably just a drop in voltage causeing the shut off. not a full discharge of power. I just got the Autostop Eliminator and will hope this will just cut the problem out all together as i dont want that feature anyways. save on gas milage my ...
Hooked mine up last night. Wired them into the dome lights. Thanks Smoothbassman!
  • Like 3
  • 3 weeks later...
On 10/22/2018 at 7:54 AM, 2019_Silverado_HC said:
I installed some RGB footwell lights this weekend (picture forthcoming) and part of the project involved locating a switched power source and preferably one with retained accessory power.  In the right fuse panel (passenger side) by fuse F27 which is a square shaped fuse, there is an additional prong next to it that will accept a spade connector which you can then run a wire to a separate fuse for whatever you are installing.  I hope this helps someone else since wiring diagrams are not readily available on the net yet.  Enjoy!
Thank you for taking the time to post your suggestion.  My 2015 Silverado did not have the panel on the passenger side  so I was unaware it even existed. My dash cam now works as it should.
  • 4 months later...
On 2/11/2020 at 9:24 PM, JAshworth03 said:
Exact same boat!!!
Hey guys not sure if your still trying to figure this out but I have the same kit as you. If you want he lights only to come on with dome lights you just connect the power wire to the pin for the domes on the bcm. If you want it to come on when you enter and exit but also want it on while your driving you run the power wire through the grommet to the engine bay and wire it to the purple wire on your headlight harness. That is the parking lights wire. Then run the accessory wire to the dome light wire in the bcm. This is the way I have mine set up. It took me a while to figure it out. For some reason when you try hooking your power wire to the bcm headlight wire it doesn’t do anything. So if anyone is still looking to do this and want it to work this way. This is the way to do it. No relays needed as this kit has a control box. If anyone needs help just message me.
I haven’t messed with mine since the original install, but I really want mine to come on during door open/close and while driving. That setup sounds like exactly what I want. Do you have pictures of where on the BCM it connects? I’m sure I can find the purple headlight wire but I’ve had a hell of a time finding the dome wire, especially since online diagrams are sparse. It would be awesome if you did a short writeup based on the wires you tapped. Thank you for the update, you’ve re-piqued my interest!
    B07
    B07
  • Who's Online   3 Members, 1 Anonymous, 771 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
