I installed some RGB footwell lights this weekend (picture forthcoming) and part of the project involved locating a switched power source and preferably one with retained accessory power.  In the right fuse panel (passenger side) by fuse F27 which is a square shaped fuse, there is an additional prong next to it that will accept a spade connector which you can then run a wire to a separate fuse for whatever you are installing.  I hope this helps someone else since wiring diagrams are not readily available on the net yet.  Enjoy!
  • Thanks 1
Good info, thanks.  I will be adding foot-well lighting  as well.  Hate getting in and not having it.  It is standard on my 2002.  Can't believe they got rid of it.
  • 1 month later...
 Has anyone had the issue of this power source cutting off and back on when the truck cranks from auto stop start ??????
  • 1 month later...
I take it this power source works with the interior lights?  As when you open the door they come on and then go out?
On 12/5/2018 at 11:50 AM, 2019_Silverado_HC said:
No issues on my truck.
If this connection has retained accessory power, are your lights always on?
RAP only stays on until the driver door is opened.
Yeah I figured that out after I wired it up lol. I was just concerned because my car charger stays on with the truck off and thought that was the "retained" accessory power
Sent from my SM-G965U using Tapatalk
OK on my 2019 that connection is always hot.  Anyone have any more suggestions.  What is an easy way to test it to go off when the dome lights go off?  It's just me so no other help to turn on and off things while I probe with a test light.  I tried the one by the 50amp fuse and it was always on as well.
Edited by Black02Silverado
I hooked up to the one by the 50 amp and my lights will only come on once the truck is running, not with dome lightsd824b4c227ce77ce0cb3591799ae7f27.jpg
Yep, problem is, mine are just LED's.  No controller so they stay on all the time while driving.  Not sure How I will like that at night.  Would rather have a switched source that is connected to the  dome lights.  I just need to find the wire to tap into.
That's what I did on my Tacoma. I had the foot lights and rock lights on with my done lights. If you find that wire, please let me know
I'm looking for the same thing (dome Light control) I am definitely missing footwell lights (as well as puddle lights.)
I don't believe it's something we're gonna find in the fuse box.  It's more than likely gonna be a bcm plug.  I think it was grey on the last gen trucks.
Im not a fan of splicing into those wires so I'm thinking of making a pass through plug with a tap of the dome light wire.
Same with my high beams to aux lights.
I'll do some digging when I get a free weekend and let you know.
Below is what I've found so far.
Edited by MadCaddie
  • 2 months later...
Anyone figure out if this is possible yet?  I know on the previous years you could tap into the BCM plug.  But wondering if anyone has done it on the 2019's yet?  I would love for the LED's to go on and off with the interior lights.
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
