On 10/25/2018 at 8:40 AM, 2019_Silverado_HC said:
A couple of pictures...
That looks legit!
  • 4 weeks later...
  • 1 month later...
Has anyone had any issues with the integrity of this 12V swithced power source?  I have noticed that the accessory I have connected to the metal spade connector mentioned above loses power when I open and then shut the driver door while the truck is running.  Sometimes the device powers back up but sometimes it stays off so it's compeltely inconsistent.  It's for a Antilaser Priority Laser Shifter so definitely concerning when it will randomly shut off while running around town.  Could this be a voltage drop or a ground issue?  It just seems odd that it would only happen when closing the door to the truck.
  • 4 months later...
Hey all! Some great tips in here. Did we conclude that a t-tap into the gray wire on the BCM in the driver’s side footwell is the place to go to power these when the dome lights come on/go off? Thanks!
On 7/13/2020 at 10:56 PM, Alex K said:
I haven’t messed with mine since the original install, but I really want mine to come on during door open/close and while driving. That setup sounds like exactly what I want. Do you have pictures of where on the BCM it connects? I’m sure I can find the purple headlight wire but I’ve had a hell of a time finding the dome wire, especially since online diagrams are sparse. It would be awesome if you did a short writeup based on the wires you tapped. Thank you for the update, you’ve re-piqued my interest!
Alex,
I'd encourage you to look at page 2 of this forum thread. Smoothbassman has a pic and a description of where the correct wire is on the BCM.
28 minutes ago, Daryl Casey said:
Alex,
I'd also encourage you to look at my comment on page 3, from July of last year. That grey wire on the BCM doesn't work as intended
My apologies. I thought that was what you were looking for.
Looking at the GM Upfitter manuals (page 7-250 of the electrical manual) https://www.gmupfitter.com/pdflists/view/45  the electrical connector you want is BCM X1 (white plug) pin 23 (Gray wire) it is the 2nd gray wire on the plug closer to the bottom.(Bottom row, 2nd in from right)The plug wires are numbered if you look at the plug from the side where the wires go into it.
That is the one that will dim the cabin lights. I've tapped into that wire for my footwell lights and they dim just like the OEM lighting now.
Hope this helps,
DC
Edited by Daryl Casey
  • 5 months later...
It's interesting but in my 21' AT4 while my BCM X1 white plug has gray wires in pins 21 and 23, pin 23 does not have significant voltage when the dome lights are on, it only reads about 0.1v above nothing.   Now I did add 2 LEDs to the overhead console and tapped into a gray wire up there and they work fine as per:  https://www.gm-trucks.com/forums/topic/232272-interior-lighting/?do=findComment&comment=2476751
Not sure if that would have impacted things at the BCM plug.  I can also add that if I remove the white BCM X1 the dome lights immediately die, but I have not been able to identify the wire in that plug that appears to trigger them.
It's driving me quite bonkers actually, because so many of the resources say that's the place to tap into under the drivers area, but it absolutely does not work on mine.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
