3,300 lbs Payload
There's a work truck doin' work.
Drive safe my friend.
Thanks. I just had to go around the block. So relatively low risk despite the load. Still scary AF though.
Nice!  Good that you are not going far.  The tires would be my main concern if they are not load range E or higher.
I do have load e! I've always used load e on my trucks because of the extra puncture resistance. I drive on a lot of construction sites. Even had load e tires on my Tacoma.
1 hour ago, 1SLOW1500 said:
Nice makes we wonder what a 2500 inside frame helper bag would do. Bet no one could even tell.
Sent from my SM-N950U using Tapatalk
It would be pretty far over the axle capacity though. I'd be able to tell when the axle tube seals started leaking!
