16' led fog light
Joshgh
Led fog light stopped working at 46,000 dealer wants $700 to replace the led strip, part is 200 what would you do?
Change it yourself
1 hour ago, Joshgh said:
Is there a good repair Manuel you would prefer?
If its just thr foglight. Unplug the light. Pull the light out. And replace it with a new one. 10 minute job
Josh, most of this stuff is pretty straight forward. Unscrew whatever is necessary in order to access the lights. Keep track of how everything came apart and where the screws came from so you can reassemble. Take pictures if needed. Once you access the lights, unplug them and replace them. Usually either screws or clips hold them in. Then reassemble. It’s more busy work than it is difficult. I’m sure there’s a YouTube video out there of someone disassembling the front end to get to the lights. On my 2014 Sierra, removing the wheel well liners (and wheels, but you could just turn the steering wheel too) gave me good access to the fog lights (specifically for access to the housing). If it’s just a bulb change, it can be done from under the truck without any need to disassemble. I suspect yours are different than mine though.
4 bolts that hold it in.  Its not just the light portion, rather its a whole lamp assembly.  You might have to loosen up the wheel house liner to see if there is enough clearance to sneak it out, otherwise GM says to pull the front bumper off to get to it.  Alldata books time at 3.5 hours.
Driver side is 84000613, passenger 84000614.  Retail for $240 each side.
Thank you for taking the time to reply, very helpful. I applied for GM assistance and got it done for $218 out the door.
I'm close to Prospser, next time, hit me up, I'd do it for half the dealer price ;)
17 minutes ago, Joshgh said:
Nice, the problem is that the light itself is $240
Not from ebay they arent :)
