How does a car qualify for lemon law?
Under the law of most states, for a vehicle to be considered a lemon, the car must 1) have a "substantial defect," covered by warranty, that occurs within a certain time after purchase, and 2) continue to have the defect after a "reasonable number" of repair attempts.
I called Onstar. They show all systems failing.
Module Diagnostic Code Diagnostic Information Recommended Action
ECM - Engine System None Failed to Probe Module None
SDM - Airbag System None Failed to Probe Module None
VIU - OnStar System None No Error Code Found None
TCM - Transmission System None Failed to Probe Module None
BOI - Bulb Outage Indicators None Failed to Probe Module None
ABS - Braking and Stability System None Failed to Probe Module
Yay! 217 miles on my 2020 Trail Boss LT and it's showing the following errors:
Service ESC
Service Trailer Brake System
Steer assist is reduced, drive with care.
Parking assist not working.
I was messing around with the app last night, remote started it via the app and now all this bullshit pops up.
Lame.
Mine does it regardless of type of start. The common factor for me is it’s always after parking somewhere for a short amount of time. Like go to the store for 15 minutes and when I start the truck to go home I get all the codes.
Service ESC
Lame.
Is your power steering working at all?
All of these issues are unique and different but all of our issues seem to be a bunch of random electrical nonsense BS going wrong all at once.  All of you, call GM and complain!
Edited by BlaineBug
It’s related to the remote start.
did it again. I have to turn off. Open door, close door restart. Engine light stays on, but errors go off.
I have unplugged my iPhone.
when errors are on display brake pedal not Working. So it affects the brakes. I will check power steering. Went to Oreilys. Threw five codes.
Makes me wonder if this has something to do w on star. I’ve used that remote since I bought it in Sept. just started today?
something has changed.
Maybe on star getting hacked?
Mine has done it since I bought it in early December. ~1700 miles on it now and it has done it randomly since it had 50 miles on it. Exact same symptoms as others, though I've never lost brakes. The brake loss is covered in another thread and does seem to be specific to remote start via the app. I don't think the issues in this thread are related to any sort of OnStar hack or problem.
Service ESC
Service Parking Brake
Check Engine Light
Steering Assist is reduced
Rough idle/misfire
Shakes violently above 50 MPH when it's in this state
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,829 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
