How many miles - major engine or trans issues?
On 12/11/2018 at 11:30 AM, seamus2154 said:
In my reading on these forums I have seen several with trans failures from 160K-200K. Most state no maintenance. I find many people to neglect/forget to ever service their trans and differential. I will be servicing using the severe service recommendations and hoping for better. I swapped the stock crap rear differential fluid over to Amsoil early at 5K and will do my trans at 50K intervals. I do tow occasionally but I am in Florida heat all the time.
What differential fluid is used from the factory? I think it's almost unheard of a differential going bad is why I ask.
My brother in law has had several Tahoe- suburbans and a pickup. They buy cpo or used. They are used as the main ride for 200K then he puts another 100K on. One required a rear end replacement. He just bought a 13 Tahoe first cylinder deactivation vehicle for him. The one he took weathered well still looks good.
An AC Delco 75/85W. I have owned 4 of these trucks and changed the fluid on 3 of them early on. All were dirty break in looking fluid, not pretty. I was very happy I had changed it as I tow a bit. Amsoil is fantastic stuff. Not many diff failures at all, but I maintain to keep things for a long time.....which didn't happen with any of these trucks!
It's always good to change the fluid from break in.I thought you were talking about the quality of the GM fluid.
The GM fluid is synthetic but is thin and IMHO not looking too good in less than 20K. I do oil analysis on most fluids but didn't on this as nothing would sway me to use it again. I have used Amsoil for 20 years w/ analysis and it looks like new 30K later and didn't need changing. There is not a lot going on in a properly set up differential, broken in correctly. I doubt there could possibly be an issue using the GM fluid. I just wanted better.
1. 2015 - 5.3 - 71,000 miles no issues
2.2015 - 6.2 - 38,000 miles needed all lifters replaced and camshaft
3.2016- 6.2 - 15,000 miles also needed all lifters replaced and camshaft
  • 1 month later...
I just bought a 17 Sierra with 90k, the service history only showed routine maintenance.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
