Need help with lean code p0171
05 Tahoe 5.3 LM7 has constant code P0171 and p0300. Scan tool data shows misfire on all cylinders in bank 1. Cylinder 1 is the worst. Constant misfire almost as if cylinder dead. Check engine light flashing. Exhaust doesn't smell right. Any help would be appreciated! Have a bunch of other codes but want to get to bottoms of this one. Will upload media shortly
Thanks
   The first step in the diagnostic procedure, would be to find a common link between these codes, especially if they all happened at once. You would want to read through the links below, and try to find a common possible cause. If most of the codes share a possible cause of "plugged fuel filter", then that would be a good place to start. If you cant find a common possible cause, then you would want to start at the top of the ladder, and work your way down - meaning that you need to prioritize the issues. Your O2 sensor codes could be a symptom of another problem, or they could be the cause of a problem. Try to fix the things that are not a possible symptom first. If you replace the O2's, and the codes were actually a symptom of another issue, then you accomplished nothing. Also, don't be afraid to clear the codes, and see which ones come back. Many times, some of the codes don't return, either because the code was a fluke, or because the computer reverted to factory defaults and stopped looking for signals from that sensor after detecting an unexpected value, and if its not looking at the sensor readings, the computer will never automatically test that sensor again until the codes are cleared.
https://www.autocodes.com/p0300_chevrolet.html
https://www.autocodes.com/p1133_chevrolet.html
https://www.autocodes.com/p0171_chevrolet.html
https://www.engine-codes.com/p1626_chevrolet.html
https://www.2carpros.com/questions/2003-chevrolet-impala-code-u1064
https://www.obd-codes.com/p0131
Thank you for info. I believe the two oxygen sensors and misfire code are result of p0171. I think there is intake leak somewhere but need to smog test to confirm.
You can find intake leaks using starting fluid. Make sure the engine is cold, and then start the motor. Spray the starting fluid around all the gaskets on the intake manifold, vacuum hoses, intake tube etc. If the engine revs up, you have a leak. You can also find it using a smoker.
Yes, yes, I know - people will say DON'T USE STARTING FLUID!
The people that say NOT to use starting fluid that way are 100% correct (according to the instructions on the can).
People that DO use starting fluid that way have been doing it for years without any problem.
Obviously you should have a fire extinguisher handy, only do it on a cold engine, and don't SOAK the engine. Just use light little puffs of starting fluid. If anything starts to get wet, wait a minute for it to evaporate before you continue. Only do this outside, never in a garage.
If your going after P0171, I would not start with a vacuum leak unless it has a high/wandering idle.
I would start here:
Check/clean the PCV valve and tube
Clean the Mass air flow sensor
Add some strong fuel injector cleaner
Check fuel pressure
Those are quick easy things to check, and just generally good maintenance items to do anyway.
Then I would move on to other stuff. I just like starting with the easiest quickest thing first. Sometimes it pays off.
Curious about the white exhaust,any progress?one thing to do would be swap front 02's,see if code stays with the bank or swaps with it
Or how about the screwdriver to ear test, other end on injector,listen for clicking, check them all to learn the proper sound
Problem was faulty B1 S1 oxygen sensor
Replaced with OEM Denso sensor
Cleared codes, no issues with engine, no misfires, exhaust smell and smoke went away
Thanks to all who left responses!!!
