Allison Farewell in 2020?
19 hours ago, silveradosid said:
Lol your a real truck driver and don't need an automatic and I can tell you that disc brakes are not that great with maintenance
Yeah that "real truck driver" stuff is thrown around by folks who have never really done much with trucking.   One thing I have learned is to work smarter, not harder.  I would like to see those that use that term "real truck driver" handle a 4x4 double transmission on a hill with 45,000 lb in the box and no power steering.  I am quite tired enough of even dealing with the nice and easy 18 speed in mine.  I would much rather have Allison do the work for me.   Nothing left to prove.  Plenty of worn out T shirts of all my adventures.  Now time to just take advantage of some of the newer technology if I buy another tractor.
  • 1 month later...
On 12/7/2018 at 7:05 PM, NOVA99 said:
Allison is the greatest.  Part of the reason I own the DMax/Allison platform is because of the drivetrain alone; even with some of the GM shortcomings like small cabs, no pano roof, offset steering wheel, lack of HVAC in rear seat of crew cab, etc.  Sounds like a true Allison is gone?  I love more gears and an Allison 10 SPD sounds awesome...but it will not be an Allison built in Indy (Speedway).  Just a marketing strategy with a name slapped on the hood.    Developing of course...True/False..or Comments?
http://gmauthority.com/blog/2018/12/2020-silverado-hds-allison-transmission-isnt-really-an-allison/
The Allison they've been using this whole time was built in a GM transmission plant in Baltimore.
https://plants.gm.com/Facilities/public/us/en/baltimore/news.html
And GM owned Allison when the transmission for the pickups was developed....
https://www.reuters.com/article/idUSN0723542720070807
Yes, I realize improvements have been made to it to get match the upgrades to the Dmax.
Yep. They've been pretty adamant in stating that the 10-speed was developed with involvement of Allison's engineers during development, testing and validation. Some gears are calling it marketing speak but the quotes I read were by engineers. Typically when engineers talk about testing and validation, it means actual testing and validation.
If this is a deal breaker, they must not realize that the L5P had way less involvement by Isuzu than the previous engines did.
  • 1 month later...
On 12/7/2018 at 8:08 PM, pronstar said:
Interesting.
GM tranny, branded and tested by Allison.
Is the current tranny a true Allison, or the same dealio?
More like Ford trans, tweaked by GM, tested and badged by Allison.
You do realize this is just an up-sized version of the Ford-designed 10R80/10L80, right?
It's just a larger diameter case/shaft/clutch variation of the same Ford-engineered transmission architecture.
And before anyone bothers to quote press releases, the 10-speed RWD transmission was NOT an equal cooperation between Ford and GM.
Ford took on the 10-speed RWD transmission engineering duties and GM took the 9-speed FWD transaxle engineering duties in return.  That was how the JV actually worked.
  • 8 months later...
I recently purchased a 2020 Chevy silverado 3200, duramax -10 speed "Allison" equipped.  As I was driving off of the dealership lot and coming to a low speed stop, the truck lurched abruptly forward and then sharply rebounded in manner that resembled the sensation of being struck from behind by a following vehicle. The service dept. at the dealership advised that this is a "known transmission issue" with GM and a TSB has been issued. I asked how many vehicles are involved but could not get a clear answer to that question.  I am wondering if other contributors to this forum have any additional info.
Yes, ford did the LD rwd 10 speed and GM did the 9 speed FWD,
Both the HD transmissions were developed outside the JV.
Ford's new 10 speed TorqShift is something of a scale-up of their light duty (shared with GM) 10 speed automatic, but the new Allison 10 speed in the GM HD's is a different design.  I have seen both of them
  • 1 month later...
I have a GMC 3500HD Denali Diesel.  At 500 miles I've noticed a cowling/howling vibration sound when doing 73-75 MPH.  After playing around with manual shifting, this issue only occurs when in 10th gear.  If I drop it to 9th, it goes away at that speed.  But then when I drive 68 MPH in 9th, I get the same issue until I drop it into 8th.  In both instances, the tach read exactly 1500 RPM.  I've also had a few instances of the same noise with jerkiness when decelerating quickly between 50 and 40 MPH.  Taking to dealer next week.  Hoping it is a reprogramming but knowing how GMC has been lately, they will probably say it is a known issue and we're "working on it".  Deal with it until we fix it.  Seems to be their MO in recent years.
Allison has no say in GM transmission specifications. GM got the rights to build the Allison 1000 Series transmission in GM factories (Baltimore) as part of the sale of Allison away from GM (Allison had been part of GM since 1915).
It turns out the owner of the dealership where I purchased my 2020 silverado 3500 has a brother who purchased an identical vehicle and had an identical problem with his. Needless to say, a couple of GM engineers responded to diagnose the problem and concluded that 4 one use bolts that attach the transfer case to the transmission were slightly out of line, presumably because they were "undertorqued" and had slipped slightly out of alignment as a result.  New bolts were ordered ( it took three weeks to receive them )  and were installed and realigned but torqued now to 70 NM instead of the factory 35 nm.  This procedure fixed the problem on both the dealership's brother's and my identical vehicle.
Probably doesn't help you but I have almost 14,000 miles on mine now and it has been flawless, big improvement over my 2017 2500 with the 6spd.  Hopefully its just an isolated issue on yours.
Hi Not Happy, when you said you had an identical problem, were you referring to my post and the 1500 RPM / 73 MPH / 68 MPH issues?
Not sure if this is the same coastdown/decel noise, but there is a bulletin regarding one that can be documented at a slower speeds.
https://gm-techlink.com/?p=12285
Transfer Case NVH Issue During Coast Down
November 20, 2019
A transfer case noise, vibration and harness (NVH) concern may be found on some 2020 Silverado 2500HD/3500HD and Sierra 2500HD/3500HD models equipped transfer cases RPO NQF (Electric Shift Cont, Two Speed Transfer Case) or NQH (Active, Two Speed, Switch Activated Transfer Case). In some instances, a clunk sound may be heard during a coast-down event.
The NVH condition may be the result of a misalignment between the transmission output shaft and the transfer case input. (Fig. 15) The misalignment could cause the transfer case shift collar to slip out of engagement.
F15-trans-1.jpgFig. 15
If these conditions are evident, road test the vehicle up to 40 mph (64 km/h) on a smooth, flat road. Allow the vehicle to coast in Drive to below 10 mph (16 km/h), without using the brakes, and listen and feel for any bumps or clunk sounds from under the vehicle. Repeat these steps at least eight times in order to verify the condition.
If the sound is verified to be from the transfer case, the transmission output shaft may be misaligned. It will be necessary to disconnect and reconnect the transfer case to the transmission.
Misalignment Correction
Remove the three transmission mount nuts, the rubber hose from the transmission crossmember, and the transmission crossmember. Also remove the transmission mount from the transmission and discard the mount bolts.
Loosen all 12 transfer case bolts, but do not remove the bolts. It may be helpful to use a screw jack to raise and lower the transmission for better access to all of the bolts.
With the bolts loosened, slide the transfer case rearward so there is a minimum gap of 1/2 inch (13 mm), but not more than 1 inch (25 mm). (Fig. 16) Next, slide the transfer case forward until it is contacting the transmission again.
F16-trans-2.jpgFig. 16
Tighten the 12 transfer case bolts in the following sequence. Torque the bolts to 41 lb.-ft. (55 Nm). (Fig. 17)
F17-trans-3.jpgFig. 17
TIP: When tightening bolts 10, 11, and 12 in the sequence, remove the bolts and clean the threads on each bolt and in the transmission with brake cleaner, and then blow out the hole with compressed air to ensure there is no fluid left in it. Failure to do this may lead to stripped threads.
Be sure to use two new bolts when installing the transmission mount on the transmission.
Reinstall the transmission mount nuts and the rubber hose to the transmission crossmember.
Refer to Bulletin #19-NA-216 for additional information.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,659 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
