LED lights for truck bed
jfuerte
Must be the Lortab [emoji2957] I tried to just hit the unlock on my fob, I thought if I had it right they would come on for 30 seconds. I’m gonna have to re-read the thread again lol. The other thing is when I put the wire into the brown connector it went right on in as if nothing was there, thought hummm, then I bent the other end and put it in the pink connector side and it too went right on in with absolutely no resistance. I’m sure you’re chuckling, picturing a heavy old man upside down and sideways, cell phone in hand, with a slight buzz attempting this task! I’m laughter myself right now [emoji16]
That will work if it's dark outside or if you cover the sensor on the dash.
And as always... Enjoy your ride!
Sent from my SM-G955U using Tapatalk
PM sent
On 12/15/2018 at 10:25 AM, xMEATxHAMMERx said:
Diode 1N4004 put into those slots. The diode are cheap, but I bought them online. So I ended up with 50 of them... I paid 5.99 for the pack of diodes, and I use that more then anything else!
Getting anything out of the bed, tap the unlock button and they light up for 30 sec. Takes longer to unload, tap the button again. Or of course you can go hit the switch in the cab, but then you got to turn it back off.
Diodes
KitchenAid KSM150PSER Artisan... https://www.amazon.com/dp/B07CDCTZ8R?ref=yo_pop_ma_swf
Bed lights
Megulla Truck Bed Light Strips, LED Truck Bed Lighting Kit with On/Off Switch and Fuse -Super Bright LED, IP67 Waterproof -for Trucks, Trailers, Pickups, RVs, Vans and Cargos (Cool White, 6000K) https://www.amazon.com/dp/B0711FYXSM/ref=cm_sw_r_cp_apa_i_EYrfCbBDYTBZ2
Cargo light bulbs
Yorkim 194 LED Bulbs Xenon White 6000k Super Bright Newest 5th Generation, T10 LED Bulbs, 168 LED Bulb, LED Bulbs for Car Interior Dome Map Door Courtesy License Plate Lights W5W 2825, Pack of 10 https://www.amazon.com/dp/B00JRE38EA/ref=cm_sw_r_cp_apa_i_8VrfCbBBKC0BP
Reverse light bulbs
Rayhoo 2pcs 1000 lumens Extremely Bright Canbus Error Free 921 912 T10 T15 AK-4014 45pcs Chipsets LED Bulbs Only for Backup Reverse Lights, Xenon White 6000K https://www.amazon.com/dp/B01EJKIUP8/ref=cm_sw_r_cp_apa_i_bXrfCbN8ZBFJWbc35d91c056a2cd6f20bb59779576af4.jpg
THANKS
Did mine last night
 48894167_10103086648598505_6637375565122
  • 6 months later...
On ‎12‎/‎15‎/‎2018 at 9:25 AM, xMEATxHAMMERx said:
Cargo light bulbs
Reverse light bulbs
How would I know if these are the right ones for my truck? I am going to do this mod but want to make sure I get the right LED bulbs.  I have a 2015 sierra 2500
  • 1 month later...
They should be the same since its the same basic platform. You can always just google the light sizes for your specific truck or search Amazon with your specific vehicle.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
