Need help with future plans
MCourson
Ok as most you you know I have a 1994 Chevy C1500 reg. cab sportside with a TBI 5.0L. In 5 or 6 years this truck should have well over 200,000 miles and I will have bought a newer OBS truck for a daily driver. I want to make the 94 a sleeper. For driveabilty purposes I want to limit it to about 425hp with an automatic transmission. I have the engine building part covered, thats no problem. What I want to have is a non computer controlled, carbureted SBC engine. We do not have emissions testing here so all that stuff doesnt worry me. Now here is what I am still thinking about. First, what kind of exhaust should I use? Most likely true duals with a scavenging pipe but should I uses cats or not? Or even better yet since I want the truck to be a complete sleeper, is there any way I could get a free flowing, quiet system that looks and sounds stock? Also on the transmission, my uncle is a GM automatic tranny guy so he can build whatever I need but since its going to be non computer controlled should I use a beefed up 700R4 or should I go old school and get a Turbo 400 or 350? Also, what computerization do I need to retain in order to keep my ABS and have all the electronics work properly. Or since this is going to be a job where I take my time should I contact Painless Performance, or Ron Francis' Wire Works and get a whole new wiring harness? Next, what rear gear should I use? Do I need to replace or modify the rear end to be able to handle the HP? Im sure there is more questions I will have to add later that I forgot.
I would go with a turbo 400, and 4:10s in the rear for a street setup. And yes, you need to beef up the rear with that much horsepower.
Not sure where the anti-lock brakes are controlled from on those years, but going without a computer at all...You might just have to live without it....Or die without it. :chevy: I seem to remember the brake controller being seperate from the puter, so you just might be in luck though.
Headers?? Just run some Zoomies up through the hood....The ricers are low enough, they might not see them. :lol::jester:
For my money though, I would squeeze a small supercharger in there though. There are some quiet ones out there (that don't require a hood mod)...that don't do anything below 2000K RPMs. That would keep it quiet until you are ready to show them your a$$.
Just my .02
Yea thats another thing. While I have the rear end out is there any decent rear disc brake conversions? Id like to have a set of Baer 4 piston calipers all the way around.
You may want to go over here:
http://67-72chevytrucks.com/vboard/forumdi...3?s=&forumid=24
for those kind of questions. That's the general engines and drivetrains board. It's not limited to 67-72 trucks as the name might imply. Lots of experts on the non-comptuerized engines though. I seem to remember someone talking about a rear disc conversion over there not too long ago...
I believe the 700R4 was computer controlled. For the power you are talking about a TH400 would be the way to go.
Why go with a carb though? Why not one of the Edlebrock or Holley TBI units that don't need a seperate engine management computer? If I had the money I would throw my Quadra-Junk in the trash and switch over to one of those TBI systems in a heartbeat. In the meantime I'll rebuild the Q-jet and get a couple more years out of it.
Mike
Grand Haven, MI
The carb deal is one thing I am sure about so far. I would like to have a Demon carb. from Barry Grant Fuel. But really it all depends of the technology then. I also really like the Edlebrock RPM AirGap manifold.
Ah, a Demon carb. Why didn't you say so? That's completely different. I've seen lots of good things about that Edelbrock Performer RPM Air Gap manifold.
The underhood supercharger is a great idea. It would quietly lurk until needed and then POW! you're gone.
Just a guess, but if you go with a non-computer engine and transmission you'll probably have to go the Painless Performance route and get a harness to re-wire your truck.
As far as exhaust goes, I'm not sure free-flowing and quiet go together very well, but maybe there's a muffler shop near you that specializes in hot-rod and muscle car exhaust that could provide some guidance? It would be nice to have something quiet up to about 2500 rpms or so and then really start to bark after that. Once the exhaust starts to bark it's too late and the ricer already knows he's beat. Hehehehehehe.
Sounds like fun. Once it's done you should be able to kill Mustangs and Camaros regularly.
Mike
Grand Haven, MI
For the exhaust, you could go the cutout route....Slight rumble at normal driving....Flip a switch and BAM! Open headers.
Cutouts seem to be the best way to have quiet and performance.
Wouldn't it also be nice to find some 4.3SS badges. :chevy:
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
