Strange oil level issue
05 Tahoe 5.3 LM7 150,000 miles
“Check engine oil level” came on on DIC about 2 weeks ago. I checked oil level but it was good. Thought it was oil level sensor cropping out and didn’t think it was big deal. Now yesterday I saw a puddle of engine oil where I park vehicle. Pulled dipstick today and NOTHING WAS ON DIPSTICK. However I pulled drain plug and 3.5 qts came out. Truck calls for 6 qts. Small puddle, but lots of oil lost within short amount of time.
Do these engines have issues with oil consumption commonly?
Thanks
I was always told the dipstick measure bar is about 1 liter in size.  If you have no oil, it could be anywhere from bone dry to 1 liter short.   I imagine you may have misread the dipstick, I need to wipe mine off and reinsert several times before i get a good read.
my 5.3 takes about 6 liters to fill up from each oil change.  I think my low oil light comes on when I’m at 4 litres
If no visible leaks, then .5 q/5000 miles would be normal , most of this would be via oil mist through pvc
As trucks, with the tendency to jump a few curbs etc, the flexing eventually leads to seepage on and number of gaskets. I'm on my 5th and every one of them eventually seeped and steadily worse until resealed. Current Sierra at 190k is losing .75 /5000 plus the .5 misting.. I my case, 2 valve cover gaskets and a rear main oil seal are needed.
Update: isolates oil leak to oil filter housing. Removed old oil filter(came off with o ring) and put on a new one pre filled with oil. Ran engine and saw oil slowly start to drip from top of oil filter housing. Anyone have any past experience in this location with a leak?
Did you check for the presence of another seal stuck to the filter mounting base?
Could be cross threaded, not tight enough, or you left the old seal on. Most seals are a pain to get off but please check. You would know if its cross threaded and the tightening issue? Check the box or filter or manual for proper tightning. Good luck
Thanks
That's not consumption problem, that's a leakin' problem!
Yes, some LS engines are known to drink a lot of oil, especially when revved above 3000-4000 rpms regularly.
You haven't by chance changed your oil brand, or from dino oil to a synthetic, have you? I've seen this happen with 2 other GM vehicles (neither had a 5.3) when I attempted to change from dino to synthetic. Changing back to dino oil stopped the problem.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
