Drivers door won't open
COP TZR
In case any of you come across this random issue in the winter. Was freezing rain all night, scrapped off truck in the morning, jumped in, got to town, could not open drivers door from the inside, tried all the usual answers(lock-unlock-key on-key off-start-drive-park, etc..), climbed out the passenger side. That afternoon, walked out to truck and found door handle pulled out a little thinking maybe it froze...nope a small slab of ice was jammed between handle and door. Removed ice, door now opens from both sides with no issue. Going to place something in there again when I get a chance to test this theory. Seems as though if outside handle is not completely pushed in it prevents the inside handle from working?
Was the little red icon with a door open on the dash, or any messages saying that it was not closed all the way? Sorry in advance, Hello 911, I am locked inside of my truck and can not get out...….
Nope, drove 1/2hr no warning lights.
To add to the issue I had 2min to get to where I needed to be, panic did set in a bit, I would like to watch the lot security footage, LoL.
Check You Tube, you might already be a celebrity….. At least you should be able to check your theory in your driveway, so someone can free you if it works.
Would like to try asap, but it was -32degC here today, not worth it. That day I was about to order everything inside the door shell. Hopefully can test this theory next couple of days.
Can not blame you with weather like that, amazing these trucks will even start and run in that temperature.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
