That is high.  I paid $50 to have my old worn out Flowmaster cut out and weld in the new Magnaflo I brought with me.   To show how prices changed, back 10 years ago I did the same thing when my first Flowmaster went bad and they only charged me $25.  They know they got you. Stinks but my welding skills suck.
I paid 40$ in 2014 for muffler delete.
  • 3 weeks later...
If I can upload a video clip under the allotted size I will. I have a 2018 crew cab with a flowmaster 10 series, flapper valve and resonator left intact. Has a nice little growl, inside and outside the cab.
VID_156451208_052501_146_1.mp4
Edited by mcglothlintoby
Added video
I picked up a couple of mph and MPG when I cut out the flapper and replaced the stock muffler with a straight through magnaflow.
Even wedged open, the flapper is restrictive. I had mine wedged open and it made a difference having it removed.
  • 8 months later...
My son recently got his 18 5.3 muffler deleted. Kept the valves and resonator in place. Sounds good all the time. Reminds me of cruising muscle cars in the 70's and early 80's. Going to do it to my 17 5.3 soon. Can't tell if mine starts when I try to remote start it from in the house. Can hear his just fine.
Im gonna put the 3 Set Ups I've had and loved
First: Deletes
Removed All 3 Cats, Muffler and Flapper and replace them with Straight Pipes
Second: Custom Full Dual 3"
-Speed Engineering Long Tube Headers
-Double 3" X-Pipes
-Twin Magnaflow Magnapacks
Third: Custim Full Dual 3"
-Speed Engineering Long Tubes
-Single 3" X-Pipe
-Same Twin Magnaflow Magnapacks
Videos of all 3 set ups:
Cats and Muffler Deletes:
Double X-pipes:
Single X-pipe
Edited by VdellaV
  • 9 months later...
  • 1 month later...
On 8/21/2020 at 7:29 PM, hlewis0725 said:
Have any of you ever had codes come on after deleting muffle..??
Not at all, only if you delete the front cats.
Sounds alright for a delete, Ive for the corsa and ive been thinking about adding the TSP headers with high flow catS
  • 2 months later...
Sorry to see that after a year, nobody still answered your question about the lack of bends in the pipe to replace the muffler. Lots of opinions though. I'm still curious if it was possible as I am cheap.
  • 2 months later...
It's possible with to weld or use clamps with a straight pipe on a muffler delete...
Edited by Kailua Knight
  • 1 month later...
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
