5.3 Idle Surge
I hear ya,you don't want to hear deep,you want out,but you can grasp it,thing is,you got to scan a pcm when all is good,then you know the perameters,yep, hindsight is 20/20
Yeah that's true, don't know unless you give it a shot, thanks again. Well I'll try spraying again this weekend with the scanner, make work with what I have and see what I can come up with
Update:
Ok, had some time and got some brake clean. Truck wasn't surging but the fuel trims were still out of whack. When I sprayed near the intake manifold, basically where the injectors are and where the manifold meets the head, I was able to get about a 20% drop towards normal on the fuel trims. Spraying the PCV line didn't affect it at all. I'm leaning towards the intake gaskets being shot?
My 05 surged every time at startup and most of the time at idle all together. It sounded like it was missing sometimes and burning rich. I read a post somewhere about adding a bottle of Chevron with Techron to an almost empty gas tank then to  fill to 1/2 tank with 87 octane and drive it as far to empty you can. (? like that will work) . . . . . NO BS,  it actually did. I now add a bottle about every 3rd tank. That was 7-8 months ago and I’ve had 0 surge/idle problems since. Truck has 170k. For $6 its worth a shot! No I don’t work for Chevron.
Thanks all for the help. Looks like next will be the gaskets to replace. I'll try to give an update if that did the trick, but it'll be awhile. Need to get the parts around and to a place I can work on out of the wind, but hopefully should do it.
I swear by techron,and cataclean now, problem solvers, back to the gaskets,it's not that bad,take the bull by the horns,and tackle it
  • 1 year later...
i would say in your case you have a vaccume issue could be in the intake fuel trim needs to be plus or minus 10 meaning if one is plus 10 the other should be minus ten with readings like that indicates a major vaccume leak more than likely the intake gaskets or even in some case the intake itsself is cracked
You might also check the exhaust for leaks (missing bolts on the exhaust manifolds, or at the manifold to pipe joint), as they can draw clean air into the exhaust, tricking the O2 sensors into reading lean.
Did you get this issue fixed yet? I recently fixed a friends truck with same codes and same symptoms that drove me crazy for a little bit and it was the intake gaskets, very easy job to do, only thing I recommend, depending on your mileage is knock sensors while your there, or at least putting rtv on the boots to prevent corrosion
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
