3 hours ago, VdellaV said:
Fixed the Pic links in case anyone had trouble with them
Yeah, I couldn’t see them yesterday. So this is for off-road use right? Oh wait, are you down in Mexico? Not trying to be a smart a$$ just remember talking to someone down there, thought it was you.
Edited by SS502
Oh wait, you’re down in Mexico right?
Yes, ahem, ahem... off road use only, of course. Just Like my catless longtubes and such
Over here we dont have problems with emissions. Living in a "developing" country has its perks
  • Haha 1
Very cool. Nice work. I'll bet this will keep your valves much cleaner than we can legally in the states.
  • 4 years later...
Hey @VdellaV -
I wanted to revive this thread to ask: Did you ever take pictures of your intake valves?
I've seen your youtube videos, and I really appreciate you sharing your knowledge with others!
I have a 5.3l Suburban, and have been searching high and low for good information (ideally with photo proof) on carbon build up mitigation.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
