Intake Carbon Deposits on new GDI GM Engines
VdellaV
Hello Everyone
As many of you know, GDI engines are more widespread than ever, and with them, regardless of how well maintained they are, they always develop Carbon Buildup on the Intake Valves and Runners, specially TurboCharged engines, and with mileage as low as 30k.
Before having a GM Truck, I used to have a VW Jetta and rolled with many friends with GDI TFSI engines, so I know this problem first hand.
The most obvious sign of Carbon Buildup is decreased performance and fuel economy, along with difficulty to star the engine or even knock under load.
What I have been doing to avoid this problem early on in my cars is to bypass the PCV gasses to an atmospheric catch can or most recently to a Crankcase Scavenging System directed to my Exhaust, so the is absolutely no source of carbon going inside of my intake, but I understand this may not be a viable solution for everyone, so I would like to present another alternative: chemical prevention.
Every 6k miles, as part of my oil Changing interval, I also replace the Air Intake Filter and chemically clean my intake using fuel injector cleaner additives directly into my intake, like if I was using seafoam.
Most Fuel injector cleaners have high concentrations of PolyEtherAmines of PEAs for short, which is a carbon detergent, the exact same active ingredient on products like CRC GDI Intake Valve Cleaner, but all fuel injector cleaners have one or other detergent for this matter.
Below, you will find a video explaining how to apply this method to your engine and another video explaining how I came to the conclusion that any Fuel Injector cleaner will do the trick:
Nicely made videos. What do you have for exhaust on that truck? It sounds amazing.
 Thank you!
Here is my setup:
5 minutes ago, VdellaV said:
 Thank you!
Here is my setup:
Nice setup! I guess they don't do emissions testing in your area? I could never get away with catless long tubes here. haha
No, I live in Mexico, I pretty much can run whatever I please lol
Do you have an upgraded driveline? Yeah that sounds killer...did you use a tune to raise your seep limiter?
No, stock driveline waiting to murder me
Im running a DiabLew custom tune loaded via a Diablo Intune i2
Got ya! Yeah man get you a new driveline before it does get you!!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
