Magnaflow questions
black18custom
Hey guys, my first post here, just had a question to see if anyone could give me some info. I have a 2018 Silverado custom ccsb with the 5.3. I'm wanting to put exhaust on it and was wondering if anyone else had a similar setup to what i was considering. Might be a long shot. I've got a single in, dual out magnaflow(approx 14-18" in length) that i pulled off a dodge parts truck that I have. I was wanting to run it with y-duals out with 3" tips. Anyone have a similar setup and possibly a sound clip to see what i would be working with? Thanks!
17 hours ago, black18custom said:
Bump....help me out guys!
I dont have a sound clip but I had a single in duel out 18" magnaflow . Ran it for a year , sound good , not loud in cab...
Changed it up recently for something different
Thanks for the info. Was it pretty loud outside the cab?
And any complaints on it? And what made you change setups?
Sorry for all the questions. I've had a Tacoma for 10 years before this Chevrolet and the tacoma I got when i was 15 so I'm pretty unfamiliar with exhaust setups for v8 trucks at the moment.
No wasn't loud , nice sound level , to me anyways , gives ya a nice rumble ,no complaints...
  Changed it up for a better flow and different sound....   I cut the y pipe before the 3rd cat , ran duel  2.5 pipes out the back with an X pipe
Nice nice. You possibly got a pic or sound clip of your current setup? Just weighing out options right now so I get the sound that I'm really looking for
2 hours ago, FlipZ71 said:
No I dont but I can snap one tomorrow...
Hate to trouble you but if you get a chance that'd be awesome.
I found this video and the description says dual outlet magnaflow which I would assume means single inlet....would you're happen to have sounded anything like this with the magnaflow?
Here are my 2 cents:
If youre going for budget, just delete everything but the resonator, like i did a couple of years ago.
If not, Go all out for Longtubes, X pipes and the whole enchilada with the smallest magnaflows i could find, like i did a year ago.
Here are 2 of my videos. the first being just the stock exhaust deleting all cats, muffler and flapper valve, and the second with a full race 3" dual exhaust i "designed":
Loud exhausts take away from the riveting experiences hearing suspension noises when off-roading lol
Wait......did you hear that, what? Sounded like something cracked and broke off. Nah, just punch it cause all I hear is that cool exhaust sound lol
Sent from above
I've got a Flowmaster Super 40 single in, dual out that sounds very similar to that.
That's pretty much the sound I'd love to have. Do you just have the stock muffler cut out and flowmaster added without any other modifications?
No rain today so here's some pics...
Some reason my sound clip wont load up...
    • Survey says yes based on the first engine to be released for the Gen 6 engines, the LS6 in the 2027 Corvette.   LS6 has DFM.  Lifter QC and construction has been improved (better/larger locking pin).  Bottom end has dual oiling circuits instead of one like on the gen Vs.     The internet (i.e. Facebook) sleuths saw that patent for a rocker arm cylinder deactivation on a pushrod engine and is running wild that all of the Gen 6s will have this when so far...none do.     Service manual, parts catalog, etc. on the LS6, its got 16 active lifters and has DFM.
    • I toggled my updates off a couple of years back. Since I don't have any CEL activity and the truck runs fine I'm happy to refrain from rolling the dice. I figure they've got it as good as it's gonna get. Recalls are another matter and I will strongly consider those if I get a notice in the mail.
    • We'll know soon. But at the end of the day they'll likely not take owner aggravation and costs into consideration. Probably the most important factor to them will be bottom line, along with units sold. Did they make money off sales of AFM/DFM-equipped vehicles? If yes, and the margin was large enough in spite of warranty and recall costs, I don't know that they will consider much else. Aside from government involvement of course, as in EPA and other regulatory bodies.
    • HM oils and cleaning. Well, soft deposits yes, perhaps. Like you say esters are present in in theory that should be a plus. But, is there enough? 🤔 The marker is the "Aniline Point" and it has to be pretty low to solve out baked on deposits. The softer sludge, yea, they do that and that is the claim. Valvoline R&P is the only HM oil I know of (Jury is out on Mobil 1's product) whose chemistry is uniquely able to remove the hard stuff and not be so aggressive as to swell seals to uselessness.    Oxidation levels in virgin oils blends is a good indicator of ester level and higher is generally a lower Aniline number and at one time we could predict without the $400 aniline test it's effectiveness. AN's, alkylated naphthalene doesn't show up in the oxidation test but does show in the aniline test and has become sort of a cheaper go to but most oils only add enough to solve the additive package. Not nearly enough to clean the harder carbon materials.   To your second question about does it matter. Yes is the short answer. Deposits are insulative. Those under the piston crown for example add octane requirement for knock free running. We don't' normally notice in todays motors due to Knock sensor driven ignition R-e-t-a-r-d. At least until the full slate of available values is consumed. Newer motors also often use oil jets to cool the piston to achieve tunes that would otherwise not be possible. Deposits on either side subtract from that. Deposits in fine screens used in VVT/VVL or DFM/AFM services live and die on cleanliness and screens are front and center. Vacuum pumps as well like brake booster in the K2's.    90% of todays oils are Group II+/III blends. A few more at PAO/AN/Group II's. A few boutique oils not Walmart shelf materials have enough solvency to prevent but not remove the hard stuff. R & P the current exception. Even HPL's EC30/40 used as directed (20% max) will get the soft stuff and some varnish out but not the hard stuff.    That orange varnish isn't baked on oil. Those are fuel varnishes left when the fuel diluted in the oil drops out when the oil cools. Like sugar does in a saturated mix of sugar and water that is put into the frig. That is ring sticking material and a glue the binds hard carbon sometimes.    Name brand shelf oils are intended to provide a useful service life at the least cost and highest benefit to the OEM who is trying very hard to keep you in $500 a month payment programs where the real money is made.   Did I miss anything you asked or left unsatisfied?
    • Yes, I understand. And I was saying (poorly), that it popped up on the DIC when I didn't have that info screen up. Just like you, but for a different maintenance issue. And just like yours mine didn't need to be shown at that time.
