Ok I’m new to the Chevy world and doing any type of mods to a truck so bear with me, I have a 2018 1500 Z71 and I put a 3” front and 2”rear lift/level kit, I put 33/12.50/20x9 with no offset. I have some rubbing on the spring and control arm and was curious to know what anyone thinks about adding spacers and if so what size and how much trimming?8E0F066B-15D4-4BD0-8505-CE035D402C0B.thumb.jpeg.ff1f395f1e8ba765e2ee68b3c81f19ec.jpeg5A76B073-D2E7-4DCA-8845-8D10B4DBEFF3.thumb.jpeg.e6f759ab334aafb62199b1714818a01b.jpeg
When you say spring you mean rear leafs? Im paranoid so I get 1/2" any more than that I get nervous about the wheel stud to lug nuts.
Sorry I misspoke it’s the coils in the front, that’s where the rubbing is
Edited by Mrfrye
I would rather do a bolt-on spacer(adapter), vs slip on 1/2"er.  I ran 1.5" on my Jeep Rubi and they took the offroad abuse.  Buy brand name, hub centric.
28 minutes ago, [email protected] said:
I believe a Good hub-centric Wheel spacer called Bora, I put 2 in spacers on my truck and have had good luck with them.
With the 2” did you have to trim anything in the front
I run 305/55/20’s with a 2.5” level and was also rubbing the control arm at full lock. I went with a set of 1.25” hub centric spacers. No more rub, just had to zip tie the wheel well liner. No issues with the spacers and they gave it a nice stance.
2” spacers have been ordered, so we shall see the end result this weekend
I probably would have gone with something smaller.  Your 20x9 with a 0 offset already stick out 1" more than stock 20x9 wheels (the ones with 2" spacers pictured above).  I would have tried a 1" instead, but then you would have to trim the ends of the studs so they dont touch the back of the wheel.  3" is a decent lift in the front and you may be OK, but proceed cautiously.
Ok so they finally came in, here’s how it looks.
Mrfrye, I'm in the same boat. 20x9 with +1 offset fuel hostages on 285/55 20. I have a 3 inch front as well and was looking at spacers as my wheel don't poke out enough for me. I don't notice any rubbing but did you have to trim anything , cut anything?
It does rub with 2” spacers but only in the back of the wheel well, I’m going to NorCal trim it tonight I’ll take some pics tomorrow once it’s all done
Yes I'll like to to see that. Is the rub severe or just a bit. Curious if it would still rub with a 1.75
I like the wider stance, but when I did this on my last ATV, I started eating up wheel bearings and had to replace them twice a year.  I didn't use spacers, I got new rims with 2" offset, and that put a lot of stress on the wheel bearings and caused premature wear...
Is that a problem on these trucks?
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,716 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
