14 hours ago, Eds240z06 said:
This is from their instruction manual 12D469D4-D567-4C2A-92DC-8FFD2E1129B5.thumb.png.62a09f455212bc97a05ca844d3174570.png
Good find but I just spoke to BDS and they cannot confirm whether a 17 inch wheel will fit. He said they may have only had a 20 inch wheel to test but that they could let me know later on. CST said there are new lifts being released in 4-6 weeks but couldn't say whether it would be a 4.5", a 6" or both so that will be another good option.
Edited by Ericruiz911
I have the BDS on order and it will be installed next week. Disappointed the coil overs aren’t available from Fox yet but oh well.
I’ll let y’all know what it’s like on these wonderful Louisiana roads as soon as it’s installed.
I did talk with BDS and the stock 20’s will work with a 35x12.50. I plan to run 295/65r20 trail grapplers.
6 inch fab tech, 20 inch fuel rims, 35 nitto rode like factory till I put a load lifter 5000 on it.  Now it rides like crap.  Going to tinker with air pressures and see if I can find a sweet spot.
Search around because I believe your issue is directly related to the bags you chose. I remember seeing comments like yours with specific models when I was searching for a set for my truck.
37 minutes ago, Chris Dudge said:
Did you find a set that rode well?
Unfortunately, I did not end up purchasing any options because I was on the fence about keeping the truck but I did decide on the Hellwig Helper Springs. I just wanted it there for when I needed it and it seemed like the best option. A few folks here had them so I would recommend searching it up and reaching out to them if you can't resolve your ride quality. Also, try contacting Air Lift and see what they say.
Getting the fabtech performance w/ 2.5 dirt logic resi coilover installed in a few day when the lift gets to the shop. Any word on this lift yet?
RST Z71
BSD 6"
Fuel 20"
Nitto 35s
NFab Nerf Bars
GM Branded Borla
GM Cold Air Intake
57444743280__ED8F85C4-C6A7-4CC5-B43E-CE6BAC71023E.thumb.jpeg.e6ebbbd293d158aa57c701743021612b.jpeg
I don't think 17's will fit.   The steering arm fills up most of the 20" wheel
17 hours ago, BillyDee said:
RST Z71
BSD 6"
Fuel 20"
Nitto 35s
NFab Nerf Bars
GM Branded Borla
GM Cold Air Intake
Wow that looks nice!!   My 19 is still stock and that picture was a punch in the face!   Really nice job, thanks for sharing!
Fuel wheels are 10” wide... 4” on the inside and 6” on the outside.
  • 5 months later...
Anyone installed the 6” Zone lift yet? Just ordered my a few days ago. Rims came in today. Hope everything will be here by Friday so I can install it this weekend.??
Edited by Peacock
  • 11 months later...
How do you like your zone lift?
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 5,836 Guests (See full list)
