Mine sounded similar, more like a Styrofoam cooler lid squeaking.  My fix was the transmission wiring bundle was rubbing.  It sounds like deep in the dash but it was just under and outside the firewall.
Edited by cltsig
  • 4 weeks later...
I have the exact same noise. Did they drop the tranny to get to this?
No.  I believe it was a 10 minute fix, just reroute the wiring somehow.  I am not sure how they secured it but it has not made a squeak since.
starting to get this noise on mine now ..well check with dealer on my next oil change
  • 9 months later...
Any chance you could provide the dealer info so we can have other dealers contact them to help fix this problem?
  • 1 month later...
On 2/27/2019 at 8:59 PM, JacobC1983 said:
Mine is more of a creaking noise and it’s pretty loud, way worse when cold.  Annoys the hell out of me. Worst part of the truck actually. Happens 5-10 times on cold mornings on a 10 minute drive to work.
Hi Jacob, my 2019 tahoe squeaks in the cold weather. If you push up and down on bumper or even entering/exiting truck, hitting bumps, it squeaks. We figured out it is brake line which is rubbing on metal bracket. ( bracket is right below back passenger door). If you jiggle the black brake line correctly, you can cause the squeak (especially when cold out).
They just released a bulletin in November for a fix. It requires special tape to be wrapped around the line where it passes through bracket. Fingers crossed that it will correct the problem.. i am waiting on my upcoming appointment for a fix.
Hope this helps!
  • 3 years later...
Did anyone else get this fixed? I have the exact sqeak like a Styrofoam cooler lid or case of water bottles. It's driving me crazy. I had transmission work done so maybe the wiring bundle. What was the fix? 2019 gmc 3500
  • 2 months later...
Bump for this thread. I’ve had this issue since day one and after 15000 miles it’s gotten worse. It seems if I push my fingers in the gap between the console and upper dash it minimizes it but doesn’t eliminate it. Ruins an otherwise reasonably smooth ride. Of course the dealer says they can’t replicate…. 2020 Silverado 1500 LTZ.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
