I have a '14 GMC 1500 with about 65k.  Ive been told that these stupid trans cooler lines will need to be replaced at some point.  Ive done some pretty difficult repairs on cars before, but ive been hearing these are a pain to change.  What is involved?  Anybody have a Manual scan?
Funny you should ask I unbolted. Mine 2 weeks ago to move trans and do a rsm. And my old truck I sold to buddy had a. Line break a week ago. Old truck is a pain in the assss. The newer body style was easy. One bolt holds a block on the driver side small bolt on the bracket under trans lines cross under trans and go up the passenger side.
Just go super slow on removing the trans clips at the radiator. Small hook tool pry them up and out. Remove line them and I mean right then gently put the clip back on. The new line will just push back on. Lose clip and other then yelling and throwing things your done.
I’ve been researching how to plumb my auxiliary trans filter. I plan on installing a -6 AN Flare Male to -6 AN O-Ring Boss adapter on the cooler and radiator on the driver’s side and removing the small steel tubing.
I can’t say 100% that the correct thread is -6AN ORB (9/16-18 TPI) but after tons of reading that is what I’ve decided to try. I’ll post here to let you know if it works.
LSX Innovations is one of a couple companies with an adapter to convert the trans cooler manifold to AN fittings.
https://www.lsxinnovations.com/product/6an-6l80e-6l90e-transmission-oil-cooler-manifold-fitting/
Want to see a photo when you're done of the radiator connections please.
  • 4 months later...
I finally finished this project. I’m really happy how it turned out. I purchased Russell part number 670300. It’s a push-lock hose barb with a -6 male an fitting. I cut off the first barb and filed the end smooth. It fits perfectly into the GM transmission fittings. I then mounted the filter in front of the driver’s wheel with a bracket bolted to existing bolts on the frame. I also used stainless braided PTFE AN hose. So far, I’m really happy. I need to cut one of the hoses shorter and remove the nylon covering on the other hose. The nylon is useless. I’ll just paint the stainless braid with black spray paint.
They make the fitting for the trans lines so you don't have to modify and build one.
So trans line gon into the condenser only or also the radiator?
Can you post a link to the fitting? I was only able to find one that converted to a standard hose barb, not an -AN male flare.
The lines and filter simply replaced the hardline jumper between the radiator and condenser. My trans fluid flows through the radiator, then the filter and then the condenser.
Still looking but like this? 6an to trans cooler fitting. I was looking for 2 soni can do my line up thought the condenser. Just because it can't hurt and fittings are cheap.3860e8c456a6e77ddbd83b1d317b1308.jpg
  • 5 years later...
I know this was a long time ago whenever you replied but are you saying you can shove those lines in without having that clip taken out? Like you said take the clip out remove the line and put the clip back in immediately and then push the line in so you can push the line in with the clip in correct?
Yes. it's designed to have the clip in place then push the tube into the fitting, it is then captured by the clip
  • 6 months later...
Also, does the transmission cooler line where it plugs into the connection on the radiator have a o-ring on it? I'm just curious if the hard line itself is supposed to have a o-ring right at the flare.. not the actual quick connect fitting but the hose itself
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
