I have a '14 GMC 1500 with about 65k.  Ive been told that these stupid trans cooler lines will need to be replaced at some point.  Ive done some pretty difficult repairs on cars before, but ive been hearing these are a pain to change.  What is involved?  Anybody have a Manual scan?
Funny you should ask I unbolted. Mine 2 weeks ago to move trans and do a rsm. And my old truck I sold to buddy had a. Line break a week ago. Old truck is a pain in the assss. The newer body style was easy. One bolt holds a block on the driver side small bolt on the bracket under trans lines cross under trans and go up the passenger side.
Just go super slow on removing the trans clips at the radiator. Small hook tool pry them up and out. Remove line them and I mean right then gently put the clip back on. The new line will just push back on. Lose clip and other then yelling and throwing things your done.
  • Thanks 1
I’ve been researching how to plumb my auxiliary trans filter. I plan on installing a -6 AN Flare Male to -6 AN O-Ring Boss adapter on the cooler and radiator on the driver’s side and removing the small steel tubing.
I can’t say 100% that the correct thread is -6AN ORB (9/16-18 TPI) but after tons of reading that is what I’ve decided to try. I’ll post here to let you know if it works.
LSX Innovations is one of a couple companies with an adapter to convert the trans cooler manifold to AN fittings.
https://www.lsxinnovations.com/product/6an-6l80e-6l90e-transmission-oil-cooler-manifold-fitting/
Want to see a photo when you're done of the radiator connections please.
  • 4 months later...
I finally finished this project. I’m really happy how it turned out. I purchased Russell part number 670300. It’s a push-lock hose barb with a -6 male an fitting. I cut off the first barb and filed the end smooth. It fits perfectly into the GM transmission fittings. I then mounted the filter in front of the driver’s wheel with a bracket bolted to existing bolts on the frame. I also used stainless braided PTFE AN hose. So far, I’m really happy. I need to cut one of the hoses shorter and remove the nylon covering on the other hose. The nylon is useless. I’ll just paint the stainless braid with black spray paint.
They make the fitting for the trans lines so you don't have to modify and build one.
So trans line gon into the condenser only or also the radiator?
Can you post a link to the fitting? I was only able to find one that converted to a standard hose barb, not an -AN male flare.
The lines and filter simply replaced the hardline jumper between the radiator and condenser. My trans fluid flows through the radiator, then the filter and then the condenser.
Still looking but like this? 6an to trans cooler fitting. I was looking for 2 soni can do my line up thought the condenser. Just because it can't hurt and fittings are cheap.3860e8c456a6e77ddbd83b1d317b1308.jpg
  • 5 years later...
I know this was a long time ago whenever you replied but are you saying you can shove those lines in without having that clip taken out? Like you said take the clip out remove the line and put the clip back in immediately and then push the line in so you can push the line in with the clip in correct?
Yes. it's designed to have the clip in place then push the tube into the fitting, it is then captured by the clip
  • 6 months later...
Also, does the transmission cooler line where it plugs into the connection on the radiator have a o-ring on it? I'm just curious if the hard line itself is supposed to have a o-ring right at the flare.. not the actual quick connect fitting but the hose itself
