Ball joint popped out
Is this a know issue?
2018 1500 double cab.
3" front 2.5" rear lift/level
34" tires (275/65r20 yes I had to trim wheel well fabric)
Hit a pot hole yesterday and the upper ball joint popped out. It's still driveable the ball joint is just no longer pressed into the a arm.
Truck has 7k miles on it. Lift/tires have been on since new. I had the same lift/tires on my previous 2015 Silverado for 30k miles with no issues at all.
Don't know if this a known issue but if the upper ball joint is really "popped" out the truck is not driveable !
The ball joint needs to be replaced immediately !
The truck is not safe to drive in this condition.
Dear God, that truck is NOT drivable if the ball joint is free of the control arm.
Get it fixed before you drive it again. Do NOT drive it to a dealer/mechanic. Have it towed and tell the tow truck driver what's going on.
Sent from my SAMSUNG-SM-J727A using Tapatalk
I knew it was a risk and I should not have drove it. But I did. I just drove to the dealer real slowww. Hopefully they will cover it under warranty. Went slow dont worry! Ha.
They said it was definitely not covered under warranty and that I will need different control arms to go with the lift.
is it a "lift"?  or a "level"?  If its a leveling kit, you have too much.
Readylift has a detailed explination on trucks with the stamped steel arms and leveling kits:
https://www.readylift.com/blog/2017/07/11/upper-control-arms/
https://www.readylift.com/2-25-front-leveling-kit-w-control-arms-gm-1500-truck-suv-6-lug-2017-2018.html
Quote
ReadyLIFT has engineered the perfect solution for leveling the 2017-2018 GM 1500 trucks. GM changed the upper control arms on the GM 1500 pickups to a stamped steel upper control arm that provides minimal structural support for the factory ball joint when in a lifted or leveled scenario. This has resulted in GM mandating no lift kits or leveling kits are to be installed on these new vehicles.
At ReadyLIFT our goal is provide accurate and safe lifting and leveling solutions for our customers. Our engineering team has developed the perfect leveling solution for these new GM 1500 trucks that includes our popular CNC machined billet aircraft grade aluminum 2.25" leveling kit along with strong DOM-tube steel upper control arms. These new control arms are a direct replacement for the factory stamped steel arms and includes our proprietary heavy-duty ball joints and an industry first maintenance free anti-resistance bushing assembly that is self lubricating and features a free-rotating inner sleeve.. With this new leveling kit/control arm combination (PN 66-3086) you can now level the 2017-2018 GM 1500 trucks with assurance the vehicle will sit level, maintain the factory ride and you have the peace of mind you will never have the factory stamped steel control arm failure.
https://www.readylift.com/2-25-front-leveling-kit-gm-full-size-truck-suv-1500-ld-6-lug-2007-2018.html
Quote
NOTE: This kit will work on new 2015-2018 GM 1500 Trucks!  If your truck is a 2017 with stamped steel upper control arms, this kit will require either aftermarket upper control arms -or- the purchase of the Aluminum factory upper control arms. The stamped steel control arms on the 2017 models are known to have issues with ball-joints becoming compromised when leveling or lifting the suspension.
It seems to me GM is trying to stop us from lifting and getting bigger wheels for our trucks;
  -the Upper Control arm design limits level/lift.
  -square wheel wells that converge towards the bottom that limit tire size
 -stock tire sizes are generally smaller than Ford/Ram
-weaker control arm material, less strength to support lifts and larger tires.
-19’ trucks have a large brake cover that prevents a lot of aftermarket wheels from fitting
Just look at BDS’ website and compare the amount of lift needed on GMs to other brands to fit like sizes tires (33/35/37).
Anything else I am forgetting?
Now that's funny right there.?
Sorry I couldn't resist
Yep, kept my mouth shut long enough for him to post the inevitable...not covered :uhoh:
I see it happen all the time on 3'' level kits.  the arms are just not designed to handle those angles.  Get the correct control arms.
I had 2" leveling spacers up front on my 2014, they leveled it out and it looked great on the factory 20s. Handling was excellent. I'd imagine that any higher would need longer arms.
My opinion is if going 3in level, might as well go 4in lift. Also, I know its extra money but I have always changed UCA when lifting or anything like that. It's a piece of mind thing, plus I am working on the front end so might as well.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,266 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
