My question for all of you is. Do I have to cut the stops off the frame after I put a leveling kit on. The picture is after the 3" leveling kit was put on. It looks awfully close to the stop. 621b6574dda0eb2eca7ce8d804791bf2.jpg
Imagine any scene from dukes of hazard, but when ever they make a jump the front wheels fall off... Your bjs can't n handle missing that stop most likely. Heck if you still have factory ucas you'll need aftermarket ones soon enough.
The new upper control arms are on the way. I'll have them Thursday. [emoji41]
Will do. Thanks for the info.
It even has that new upper control arm smell.....6d90518e4a734329b6694c2a1c08af13.jpg
  • Thanks 1
  • Haha 1
No matter what YouTube says. You have to remove the strut in order to get the upper control arm bolts out!! Alot of cursing went into the installation of these. Enjoy!9c0511c456aea545a463df67ca74e72e.jpgdf8fffb9a9edba515363966b52321b54.jpgedff02e52b6b3e8d6d5f6824f582ef9e.jpg25589fdc5ba55fe7975cbd48d18ddba9.jpg
  • Thanks 1
Echo
How much of a pain was this. I have a 3 in level as well and am ordering the uca tonight from RC. Are you happy with the RC control arms? What was the biggest pain of installing them? Did you feel a difference?
Were you able to put the uca in in your driveway?
Any device before i tackle the job?
Sent from my SM-N950U using Tapatalk
EchoHow much of a pain was this. I have a 3 in level as well and am ordering the uca tonight from RC. Are you happy with the RC control arms? What was the biggest pain of installing them? Did you feel a difference?
Totally able to do it in my driveway. Do yourself a favor and completely remove the strut before you even start dealing with the uca. Also loosen the sway bar bolt. You don't have to remove it just loosen. I marked the position of the uca before I removed it. The difference in the ride is totally worth the work. Make sure you get an alignment afterwards. I took mine right to the tire shop when I was done. Good luck!
At least it will be worth it. I just remember trying to put the strut back in after adding the block to the strut for the 3 in level. What a b!+@& that was. Oh and I see you left the bump stop.... I here popp say lose it but i don't want any over travel.
About how long did it take you from start to end?
A few hours. I started around 9AM and was getting it aligned at noon. I left the stop it's really not an issue with the new uca.
Photo please of the stop 'after' sitting on the ground like you did the before please.
Installed the arms last night at the shop. Probably took about 4 hrs. Tried removing the cam bolts w the strut in. 2 came out, 1 on each side but the front ones were hindered by the spring so removed the struts. Once the struts were out it went by much faster and smoother. I think trying with the strut in added some un-needed time. I did it on a lift but could have tackled it with some Jackstands and a Jack. I advice 2 ppl just to manipulate different parts but on your own would just take a bit longer. At the shop now getting an alignment. Already feels a little better. I will say these things are beefy. Definitely worth the upgrade and price
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
