2019 bed tarp
Hey guys. Looking for a bed tarp/cover for my trailboss.
Where did you get yours from. And can I see some photos of it.
I have the custom trailboss, which I assume will be the short bed. Can anyone confirm this?
Also. Does anyone know if I could still use a bed tarp if I I install the sport bar. I have it on order to be picked up this coming week.   Hope there is room enough to put a bed tarp too.
Never heard of a bed tarp. There are a lot of posts about hard and soft bed covers, aka tonneau covers though. Tarps would flop around a lot while driving and mess up your paint for sure.
Extang Trifecta Signature Series. This is my 3rd Trifecta cover, I keep my trucks avg seven years. The Trifecta’s have held up very well. Signature series is a vinyl backed fabric similar to what is used on high end convertible tops. I’ve found it doesn’t shrink over time like a conventional vinyl tonneau does. I purchased mine from a local truck accessory dealer, expect to pay $450+-. Vinyl version available on line for around $400. Doubt it would work with sport bar tho.
Not the best pic but just to give you and idea. I can add more later if you want.
Just bought the gator bed cover.  Only 200 dollars.  Looks great.  Can’t beat that price!!
thanks again asalinasz39
Looks great bud! Give it a few days and you'll be able to adjust even better after the sun helps the material stretch.
I am glad it worked out  for you with your sports bar.
You made up my mind for me
The truck looks so nice
I will be copying the same thing with the sports bar and the cover only on an AT4
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
