2011 Sierra service traction control/service stabilitrak
Johnoneil1
When I start my 2011 Sierra I get a service stabilitrak/service traction control message on the DIC and the orange traction light in on. It happens as soon as the truck starts and before the truck moves or steering wheel moves. It throws a code U0124-00 lost communication with yaw sensor. In addition my abs is also no working but no abs light is on. Does anyone know where the yaw sensor is located and any help troubleshooting the code would be greatly appreciated. Thanks in advance
I believe that the yaw sensor is an integral part of the inflatable restraint sensing diagnostic module. Under the driver's seat carpet. Check the module and connector for corrosion.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
