Crappy trans shift profile - 2018 Sierra 6 Speed
CCGMC
I have a 2018 GMC Sierra with the 6 speed. I know this has been discussed on this forum but is there any remedy to the weak throttle tip in performance of this transmission? I have the 2018 model year so I assume I have the updated throttle peddle? I did the shim between the lower corner of the throttle plate and the firewall. It helped a little but in my opinion it’s still not right. I love everything about this truck but the transmission shifting. It just doesn’t seem right. Is there an update at the dealer I can do?
The answer is.yes there is always something that can be done but not as simple as that.
It isn't just trans or throttle, or power.
When you say throttle tip in. I assume you mean you are rolling and get it pedal and it is slow or lags? It can be afm/DOD or fuel cut off a wot pass or down shifting. Or depending on demand and rpm torque management just blocking out the power.
Yes when rolling, slowing down and then getting on the pedal again it doesn't respond fast enough. I rented a 2018 Tahoe on a business trip with the 5.3 (6) speed and it was perfect.
I was hoping the dealer has a fix for this as it's a well known condition.
If it was related to AFM/DOD, fuel cut off or down shifting what would you suggest as next steps to improve it?
There was a post not long ago that was a person same as you. Happy about truck but trans was ruining his drive quality. He had a tune done. With the trans and even the fuel tables with afm/DOD. And he raved about how much better it was and how he was amazed by the truck now.
Gm is weird... it's like they honestly cannot tune anything remotely correct but then you get the odd good one.  I have never been a stock 6 speed fan and even my 2017s 6l90e was pretty blah.. has the usual 2nd 3rd flare when it's cold and whatnot.  Tuning helped but I have more work to do with it... Then out of left field I get this low mile bone stock 2013 6.2 NHT truck.
Honestly its 6l80e shifts perfect to the point of raising the wide open shift points higher is all I want to do.  Never hesitates, never gets lost or hangs up... never flares, nice positive shifts.. nothing.  Its bone stock... so who knows lol.
take a HP tuners class and do your research, then program your trucks trans, it will be 5X better then GM tune. GM tunes their ecus and trans-puters for different reasons, not for performance or long term reliability...!
AFM kicking in and out of V4-V8 most definitely affects transmission behavior.
Try Running it in M5 to see if it improves.
There is also a transmission "learn" mode that adjusts or sets the shift points to your driving style after around 1,000 miles or so.
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
