Issues as well, Range AFM WORKED fine for a few months in my 2017 GMC Sierra w/ 6L80 transmission, the mileage was fine, drove fine.
about a month ago, my transmission acted up, wouldn't shift, over heated the transmission.
Now I was told to unplug the device and plug it in when truck was running. Then it worked again, for a while, now again, I am having shifting issues, truck shifts into high gear too soon, 1,2,3 is ok, then it goes 4th 5th 6th  too soon.
I will toss this thing and advise against anyone getting one. There are better ways. Cost me a tanny flush and reprogramming (reflash). Pfft. P.O.S.  is my opinion!
I have a 2011 Yukon XL. 5.3L At 300000 I got the miss fire warning sign. Took it to the GM dearler and was told you need a new motor. Can be installed for around $10000.00. Was not too happy about that sooooo. I bought a range AFM disabler, changed the spark plugs ( which 4 of them were badly fouled ) and now have 550000 KMS on the same vehicle with no issues what so ever. Only thing I notice is once in a while it seems to burn some oil rather quickly ...did some research and found I should have bought the AFM disabler sooner. I am a happy camper. I now also have a 2015 Yukon XL denali 6.3 L and guess what. It also has an AFM disabler and there are no issues at all. Even happier!!!
DW
  • 6 months later...
Just got my my range yesterday for my 2017 silverado 5.3 and on my way to work 2 times wen i was slowing down to turn the truck jerked while downshifting.....unplugged before coming home and drove home perfectly
Edited by PistolPete007
Misspelled words
On 5/20/2021 at 9:31 AM, Joseph Randazzo said:
I just received my Range AFM delete and on my 2018 Sierra w/5.3 engine it would slam hard shift from2-1 when slowing to stop..I had to delete the delete device.I contacted Range and they could not figure out why but know of the problem.I think the Range device somehow messes with the transmission programming in some way,but Range says no.The device kept my vehicle in 8 cyl mode but the downshifting was horrible..No good for me..
Tranny on its way out not the range had mine in since putting a new trans in at 80k it been smooth! Ps the afm slips your trans on purpose to not to feel the dod kicking in
  • 8 months later...
Unplugged my AFM (07 Chevy 5.3)Traction Control light came on started running erratic. Plugged back in ran normal.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
