Why can't you connect to the android auto wirelessly?  don't understand how it works I guess but I hate having to have a cord plugged in when there's bluetooth and wireless charging it seems like there would be a better way.  Possibly something that could come with system update later?
edited after some research.  Still should be able to do it with built in wifi and an app that could be downloaded.
Edited by Robwcormack
It's the same reason your laptop cannot connect to an external monitor via Bluetooth. There's just too much data being transferred at a high rate of speed. It has to be corded, since the radio turns into an external display for the phone when you use AA or CarPlay.
I notice that my sound system is more robust when I plug the phone into CarPlay, and my calls are even clearer, too.
Going corded - though I agree it's a bit annoying - has its benefits.
But our trucks have built in wifi.  There should be no need for internet connection to transfer from phone to truck via that wifi connection, and that would be plenty fast to get it done.  Sounds like OnStar can capitalize on it so they have to interest in making it work.
IF you continue the wifi plan and the most of us do not.
The tech is just not there yet... not in a truck, or beyond this. This is why you cannot AirPlay from your Computer to an Apple TV via a FaceTime call or phone call yet.
The next step, I think, will be Apple or Android embedding apps IN the car systems, which run CarPlay natively, and not through your phone. Instead of using a cord to connect, you just connect your phone to the app running in the truck, much like Apple does with an iPhone to Watch.
Shouldn't matter if you continue the AT&T wifi plan.  The wifi "router" is still in the truck and shouldn't require a data plan to connect to your phone.  It could simply be used as a local network between the truck and your phone allowing you to use the android auto or apple play (or whatever it's called) wirelessly.
The tech is built in because you have what is basically a wifi router in the truck.  You'd just need to create a local network.  much like in your home if you have a wifi printer.  if your computer and printer are both connected to the same wifi router in your home (i.e. local network) then you can print to that printer regardless of whether or not the internet is running.  It's not new technology at all.  And google released android auto wireless last year.  There is a developer who has been working on an app that would use a amazon stick or device with wifi hotspot capability to do exactly this same thing, but we already have it built in these trucks.
You're already a long way down a technological fix vs. your original question "Why can't we just do this via Bluetooth?"
It is a truck radio, not a home network system with extra hardware. Give it time, I'm sure we'll see something in the next 5 years. I think it will come through an embedded app, though, not a faster wireless connection to the truck and phone.
true.  did a bit of research after the initial post to realize the problem and potential solution.  It doesn't require a complicated system.  An app and the existing hardware are all that's needed.  It's just going to take an app developer with a vested interest, hopefully an owner on here that sees this, to take the idea and run with it.
Thanks, UGADawgs.
I really like the idea of being able to leave my phone in my pocket and connecting right to CarPlay when I drive my 10-15 min drive home from work. That would be awesome.
  • 5 months later...
There are wireless android auto and apple car play vehicle receivers. The technology is there in aftermarket units. GM just decided not to include this feature.
Sent from my Pixel 3 XL using Tapatalk
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 649 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
