FYI
If you’re only wanting to disable traction control and stability control for off-roading, shifting to 4-low disables both of them. At least it does on my 2016 Z71.
I wired in a switch to disable the steering wheel position sensor on my 2014. It completely kills stabilitrac and then I turn off traction control with the factory switch.
This seems like the easiest option by far, since the sensor is in the cab and you can mount the switch under the dash.
  • 8 months later...
is the #25 fuse applies to a 2018 sierra? it says antilock brake valve, nothing on stabilitrak but #3 says Antilock brake system pump. any ideas??
Edited by De Lacasa
  • 8 months later...
I have tested both options, the one with the switch on the fuse box works but on my 2018 1500 denali not only disable the stabilitrak and traction control but also disables the power steering pump, so the steering will be heavy. on the toggle with the harness on the driver side ABS harness with the switch works better because it interrupts the signal telling the computer that the ABS is not working, so in theory the stabilitrack and traction control will not work and the light on the dash will come on until you flip the switch back.
  • 11 months later...
